Add A New Circuit To A Fuse Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2013, 12:57 PM   #1
Add a new circuit to a fuse box
Howdy,
I was wondering how you connect a new circuit to a fuse box. Fuse, not breaker. I've Google'd this thoroughly and can only find examples for breakers.
In my fuse box there are two empty sockets where, I'm assuming, nothing is connected inside. Is it possible to simply run the new wire to one of these and pop a fuse in?
M_bisson is offline   Reply With Quote
Old 11-10-2013, 02:38 PM   #2
PoleCat's Avatar
Rewards Points: 1,652
Sounds logical.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-10-2013, 02:54 PM   #3
Any links or pictures? Maybe even a step by step guide? I have no idea what to do once I open it up.
Old 11-10-2013, 03:52 PM   #4
PoleCat's Avatar
Honestly I haven't been in a fuse box at least 20 years so the cob webs are pretty heavy. A picture of your set up would be most helpful. Essentially you will be wiring it up like you would a breaker. Neutral & ground go to their bus and the hot wire is screwed down at the fuse socket. Then put in the fuse that is sized fr the wire you use.
Old 11-10-2013, 03:54 PM   #5
Alright thanks. I'll post a pic next time if I can't figure it out
Old 11-10-2013, 04:05 PM   #6
Oso954's Avatar
Rewards Points: 1,320
I would suggest that you post the pic, and then ask for help.
There are too many other problems that could be going on in that box to risk experimentation, especially when you do not know what to expect.
Oso954 is online now   Reply With Quote
Micro Wave Oven blowing circuit fuse jankencanada Electrical 5 12-23-2012 12:47 PM
Dead circuit, couldn't find problem so tied into second circuit zappy12 Electrical 25 12-13-2012 09:38 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Rewiring furnace electrical circuit BlueBSH HVAC 4 09-21-2010 01:34 PM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 02:40 PM
