Add GFCI At Panel To Protect Outside - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2009, 09:01 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Add GFCI at panel to protect outside
I just want to make sure, is this ok to do? I want to locate and cut the wire that goes to my outside circuit and add a GFCI outlet and put the load on the "load" leads so the GFCI in the house protects the outside circuit.
If it matters my electrical panel is just above the washer and driver, and the wash tub is next to the washer. In fact while I'm at it my washer receptacle should probably be GFCI too right? It's about 3 feet from the wash tub.
Every time I plug my car in with my old extension cord, I'm a little nervous. I also need to replace that cord. It came with the house, and the previous owner was not very careful with the weed whacker.
Old 12-18-2009, 09:04 PM   #2
As long as the outside outlet does not pull power from a bathroom, kitchen or other required dedicated circuit
I always have the GFCI inside feeding a normal outlet outside from Load side
Many of my GFCI's (blank face) are installed at the panel
Easier to add in & easier for someone to find in the future
Old 12-18-2009, 09:15 PM   #3
Wire Chewer
Rewards Points: 138
Great, that's what I'll do then. It's a dedicated circuit so I should be fine.
If ever I install a sump pump would there be anything against plugging it into that circuit? It will give me an idea of where to locate it to make this convenient in the future.
Old 12-18-2009, 09:18 PM   #4
My sump pump pulls 7a, which is less then 50% of a 15a circuit
I do not know of any restriction that would not allow this
Code (here) only requires an outside outlet, does not have to be dedicated
And my sump is not on a dedicated circuit
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
gfci in main feeding sub panel problem scott2332 Electrical 12 02-25-2009 11:17 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
