Add On Circuit To A Required Gfi - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2008, 09:53 AM   #1
Add on circuit to a required gfi
I am wiring a kitchen. Is it ok to add additional non-kitchen outlets (say an ajacent bedroom) outlets and lighting circuits to the 20A kitchen circuit before the gfi?
smudge is offline   Reply With Quote
Old 01-23-2008, 10:04 AM   #2
waiting for spring
arichard21's Avatar
Rewards Points: 150
The small appliance countertop circuits MUST only feed outlets on the countertop. If you have ANOTHER circuit that DOESN'T feed counter outlets or anything that requires them to be dedicated like fridge, micro/hood, dishwasher, disposal, etc. If you have another general circuit feeding the kitchen that DOESN NOT supply to any of the ccts listed above, then yes you can tap off them.
arichard21 is offline   Reply With Quote
Old 01-24-2008, 09:04 AM   #3
Rewards Points: 410
ARichard has it right. Kitchens need two 20A dedicated circuits for outlets (and be GFCI protected), and since they're dedicated you can't tie into them anywhere (even before the kitchen) and only to be used for the kitchen outlets. So, not even lighting in the kitchen can be put on the kitchen outlet circuits.
Normally, kitchen lighting is usually tied into its own circuit or a lightly used one since there's usually a lot of lights. If you do a search on here about Kitchens you'll come up with previous posts we talked about which circuits have to be dedicated in a kitchen.
Piedmont is offline   Reply With Quote
Old 01-24-2008, 10:36 AM   #4
Licensed Pro
The small appliance circuits can serve the kitchen, pantry, breakfast room, and/or dining room. They are not confined to just the countertop.
Old 01-24-2008, 11:37 AM   #5
Thanks, here's another one.
I have a problem with drilling lots of holes in 80 year old 2x8 joists. Instead of running through the joists in the basement can I route circuits into the furnace room(parallel to the joists) above the ceiling, and then down across the joists to the new panel. I plan on keeping them close to a beam and then covering them with a plywood raceway. Any code problems with this?
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 08:21 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
