Old 11-20-2012, 06:12 PM   #1
Add a breaker
I'd like to add a breaker for my garage. Lots of tools may be operating at the same time thus lots of power's needed.
I live in canada so I need 120V 60AC. I was thinking about a 30A breaker.
I need to know where to place the newcomer.
I have to breaker boxes, a big (the main one plugged to the line), a small plugged to the big.
Breakers from the big box are big and the clothes dryer's plugged into it. The other has smaller breaker. Does this mean the big box is under 240V and the small one is 120V?
Olograph is offline   Reply With Quote
Old 11-20-2012, 06:40 PM   #2
JOATMON
ddawg16's Avatar
Add a breaker
Olo....I'm afraid that your way in over your head on this one.....
Additionally....unless there is more than you in the garage....I'm at a loss as to how you are going to operate lots of tools at the same time. I have a LOT of tools in my garage and as hard as I try, 2 is the most I can run at once....and one of them would be the air compressor.
Additionally...30A is an odd value for a garage...unless your running a 30A 240Vac line....
Your typical wall outlet is limited to 20A if you have the right recept....in most cases everyone uses a 20A ckt with 15A outlets.
You also have to take into consideration your lighting.
Before you start asking questions, I would do a search using the keywords garage and electrical. The topic has been discussed a lot. I figure you can spend about a week reading all the available info.
Do the reading and then post back.....by then you should have a better idea of what you need and want.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Olograph (11-20-2012)
Old 11-20-2012, 06:55 PM   #3
joed's Avatar
Add a breaker
You can not put a general use receptacle on a 30 amp circuit.
In Canada if you put in a 20 amp circuit you MUST use 20 amp receptacles.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
Old 11-20-2012, 06:55 PM   #4
Add a breaker
Thanks, I think I might ask a pro on that one, I don't know what I'm talking about.
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 08:27 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 12:23 PM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
