Adapting 240V 4-conductor - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-24-2013, 08:09 AM   #16
Rewards Points: 462
Richo, just curious, 240v and 30-50 amps for your equipment? What kind of equipment uses that?
There isn't any equipment that uses 240V. It's a "portable" sub panel with multiple 120V circuits as most venues don't have 4 circuits along one wall or in one corner.
Buy or make cheater cords (with some limitations). Here you want an adapter with a 4 prong receptacle for your portable subpanel and a 3 prong plug (hot hot neutral) to connect with the venue's electrical system. Have a green pigtal coming from your adapter to connect to a known ground.
The only easily accessible known ground in many places is going to be at the 120V receptacles and that is usually going to be only 14 gauge wire. Is that sufficient ground for a 50A panel?
Richo is offline   Reply With Quote
Old 05-24-2013, 09:46 AM   #17
Special User
Rewards Points: 1,230
Better than no ground or a bootlegged ground?
And if a GFCI is used, there should be very little fault current.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following 2 Users Say Thank You to tylernt For This Useful Post:
Kyle_in_rure (05-24-2013), MTN REMODEL LLC (05-24-2013)
two 20amp circuits on 12/3 wire Red Squirrel Electrical 30 02-12-2015 07:06 AM
240v questions.... ITSANSS Electrical 16 05-11-2011 05:40 PM
NEC Junction Box Conductor FIll: A Single Splice is counted as Two Conductors? Lovegasoline Electrical 7 12-02-2009 10:44 PM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 06:37 PM
