Adapt Post Light To Limestone Cap - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 08:14 PM   #1
Rewards Points: 462
Adapt post light to limestone cap
OK here's a little problem....
Having a brick pillar built and capped with a light. This is what will be on top:
Problem is, this lamp has a 3 1/8" ID to fit on a pole and there is only a 1 1/4" hole drilled in the cap. Sure, the ideal situation would be to have a larger hole in the cap to fit the right size pole, but this isn't the ideal situation, is it?
I'm a woodworking guy so my first instinct is to cut a 3 1/8" disc out of treated wood, attach a short piece of 1 1/4" dowel to fit through the hole in the cap, then drill a hole through the center of it all to feed the wire, then silicone it to the cap. But is there a better way?
So, the question is WWYD?
Richo is offline   Reply With Quote
Old 07-11-2011, 08:44 PM   #2
Electrical Contractor
kbsparky's Avatar
Mount a post-top adapter on top of your pillar:
-KB
Old 07-11-2011, 09:30 PM   #3
Rewards Points: 462
Ahhh...I guess it helps to know that such a thing exists.
Thanks!
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
light post jayharold General DIY Discussions 1 06-07-2009 04:46 PM
Wiring post outlet and lamp for light post Gordon Electrical 3 09-22-2008 02:39 PM
Electric receptacle in lamp post and flood light not working th31 Electrical 7 12-13-2007 07:46 AM
