ACFI Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-14-2013, 01:27 PM   #16
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
the smoke detector circuit is also an "outlet"
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 09-14-2013, 04:53 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Smoke alarm by NEC definition, just for general information, the state of Connecticut has an amendment not requiring smoke alarms to be supplied by an AFCI circuit.
Old 09-15-2013, 04:12 AM   #18
Rewards Points: 516
Interesting .... so in a RESIDENTIAL setting ....it is not required to be on a lighting circuit ???
Old 09-15-2013, 07:24 AM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Smokes are not required to be on any specific circuit. They are however required to be AFCI protected just by the nature of their location. Unless of course there is a local amendment in place.
Old 09-15-2013, 09:20 AM   #20
E2 Electrician
No, why? I generally put them on a home run since I don't have to provide AFCI protection.
Old 09-15-2013, 11:20 AM   #21
Rewards Points: 516
ok better stated ... smoke NOT on thier own circuit ....
Old 09-15-2013, 11:28 AM   #22
Rewards Points: 516
I lernt that to put it on lighting circuits so it would be evident that something was wrong ie the lights don't work or that some will turn off the breaker if it was on its own ... RESIDENTIALLY of course ... not commerical.
Old 09-15-2013, 12:42 PM   #23
Rewards Points: 528
Dont forget, soon you will be required to have gfci on wash room and dishwasher circuit too.Not sure but im assuming disposal circuit also.
hidden1 is offline   Reply With Quote
Old 09-15-2013, 12:53 PM   #24
Huh? Where are you getting this from?
And if it's not code now what does it matter?
And what are you calling a "wash room"?
Old 09-15-2013, 01:59 PM   #25
Oso954's Avatar
Rewards Points: 1,610
He has been reading 2014 code change articles. The wash room reference is to laundry room receptacles.
Oso954 is offline   Reply With Quote
Old 09-15-2013, 02:26 PM   #26
E2 Electrician
I learned not to believe anything anyone says and look it up myself... usually the best course of action. Also, there IS no residential NEC and Commercial NEC...
The Following User Says Thank You to stickboy1375 For This Useful Post:
Philly Master (09-17-2013)
Old 09-16-2013, 02:12 PM   #27
Rewards Points: 348
The NEC requires all OUTLETS to be AFCI protected, this actually equates to receptacle, lighting outlets, and the like... you need to read the NEC definitions of an outlet, and not just assume an outlet is a receptacle...
I didn't assume that. Go back and read my original post. I accept that it is what the code requires, I was just looking for the why.
Notice that joed and rjniles actually answered the question I asked.
To follow up, are arcs in lighting fixtures that much of a problem?
herdfan is offline   Reply With Quote
Old 09-16-2013, 02:28 PM   #28
Oso954's Avatar
With more and more lighting fixtures and/or controls being installed by doofus homeowners that do not have a clue, I believe that the problem is growing.
Old 09-16-2013, 02:38 PM   #29
JOATMON
ddawg16's Avatar
Rewards Points: 2,112
Here is a good example.....
This can light was installed in my in-laws house by a licensed contractor about a year before I found this problem....
Not the best picture....but the black area on the Wego connector is carbon.
I'm not going to place any blame....it could have been a mistake on his part or a bad Wego connector. (I personally don't care too much for them)
Old 09-16-2013, 04:12 PM   #30
E2 Electrician
So, do you think the AFCI will detect this and trip?
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
