ACFI Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2013, 05:51 AM   #1
Rewards Points: 41
ACFI Question
So, Im rewiring the entire house. I plan on having GFCI breakers in the kitchen and bathroom area. I heard that it is now code to have AFCI's in bedrooms and living areas, is that true? I was thinking maybe just the bedrooms? The reason being is because they are very expensive. Could I get away with not even having any AFCI's?
biddlecom is offline   Reply With Quote
Old 09-11-2013, 06:03 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Wow. If you're asking this I would STRONGLY suggest you get a code book and a few other good books on home wiring. At this point in time this is a very basic question, anbd you need to have the basics down pat before you even drill your first hole.
Also, codes do vary from area to area. Knowing your location would help with that. At least your state.
Speedy Petey is online now   Reply With Quote
Old 09-11-2013, 06:07 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
First thing you need to look up is what code cycle your state is on.
Old 09-11-2013, 06:12 AM   #4
Rewards Points: 41
My state is Maine
Back when I went to school for electrical it was not required to use AFCIs. I haven't look at anything electrical in about 10 years so im a little behind on the new code. So any help would be great. Thank you
Old 09-11-2013, 06:14 AM   #5
E2 Electrician
Originally Posted by biddlecom View Post
My state is Maine
I'm not sure what code cycle the state of Maine is on, but that info will definitely tell you where AFCI's are required.
Old 09-11-2013, 06:44 AM   #6
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
My state is Maine
2005 code required anything in BEDROOMS to be ACFI ....
2008 expanded it ... to include most areas .. less KITCHEN and BATH
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 09-12-2013, 02:43 PM   #7
maine is on 2011 but your local jurisdiction may have amendments/modifications. for example, wisconsin in on 2008 but it has 3 or 4 pages of legislative code which modifies a few sections of the 2008 nec specifically for wisconsin.
2011 at 'face value' more or less requires afci protection everywhere except outdoor circuits, garages, kitchens, bathrooms and certain fix-mounted equipment (i.e. air conditioner, furnace, etc.).
itsnotrequired is offline   Reply With Quote
Old 09-13-2013, 05:04 AM   #8
Rewards Points: 516
NEC 2011:
Section 210.12(A) requires that AFCI protection be provided for all 15- and 20-ampere, 120-volt branch circuits that supply outlets (including receptacle, lighting, and other outlets; see definition of outlet in Article 100) located throughout a dwelling unit other than outlets installed in kitchens, bathrooms, unfinished basements, garages, and outdoors. Because circuits are often shared between a bedroom and other areas such as closets and hallways, providing AFCI protection on the complete circuit would comply with 210.12. There is no prohibition against using AFCI protection on other circuits or locations other than those specified in 210.12(A).
CHANGE FROM 2005 to
For the 2008 Code, 210.12(B) requires that AFCI protection be provided for all 15- and 20-ampere, 120-volt branch circuits that supply outlets (including receptacle, lighting, and other outlets; see definition of outlet in Article 100) located throughout a dwelling unit other than outlets installed in kitchens, bathrooms, unfinished basements, garages, and outdoors. Because circuits are often shared between a bedroom and other areas such as closets and hallways, providing AFCI protection on the complete circuit would comply with 210.12. There is no prohibition against using AFCI protection on other circuits or locations other than those now specified in 210.12(B).
Old 09-13-2013, 12:03 PM   #9
Rewards Points: 348
I understand why they are mandated on receptacles, but if you have separate circuits for lighting, why are they needed? I know code says they are needed, but what is the reasoning behind the requirement.
herdfan is offline   Reply With Quote
Old 09-13-2013, 12:48 PM   #10
joed's Avatar
Rewards Points: 13,358
Lighting get loose connections that can cause fires, as well as receptacles
Old 09-13-2013, 12:48 PM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
You can have an arc fault on a lightjng circuit also.
Coastal South Carolina
Old 09-13-2013, 08:52 PM   #12
E2 Electrician
The NEC requires all OUTLETS to be AFCI protected, this actually equates to receptacle, lighting outlets, and the like... you need to read the NEC definitions of an outlet, and not just assume an outlet is a receptacle...
Old 09-14-2013, 09:46 AM   #13
Rewards Points: 236
are these needed under 2002 NEC ?
Fix'n it is offline   Reply With Quote
Old 09-14-2013, 10:25 AM   #14
JOATMON
ddawg16's Avatar
Rewards Points: 1,980
From the above one could infer that they are not....
ddawg16 is online now   Reply With Quote
Old 09-14-2013, 10:29 AM   #15
Rewards Points: 236
after i posted that. i looked on my towns www. there is no mention of them
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
