Acer 5742Z Power Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 04:59 PM   #1
Acer 5742Z power wire
Hi. I had a break in the power wire, not the socket side, so I cut the wire back, and then re twisted both wires. I get nothing if I do both, but if I do either one of the wires on their own, I get the power light come on in the power block but nothing else. Any idea why this is ? And how I can sort it ? Oh, I also covered them in E tape.
Ben
BenDansie is offline   Reply With Quote
Old 08-08-2012, 06:07 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Ben
Huh! Come again in English.
Coastal South Carolina
Old 08-08-2012, 06:17 PM   #3
"So I Re-Wired It"
MisterZ's Avatar
this is for a laptop??
i know a replacement power cord can br pricey, but it is recommended you just buy a new one.
just for curiosity, which part of the cord is broken??
the one that goes from the brick to the outlet, or where it goes from the brick to the lappy??
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-09-2012, 01:58 AM   #4
The Brick to the laptop. And it isn't a forever it's until I can get a new cord.
Thanks,
B
Old 08-09-2012, 04:51 AM   #5
Rewards Points: 3,256
Ben
You either have the polarity of the wires wrong or there is a short between the 2 wires at your splice or farther towards the laptop. Hooking both wires up completes the problem path and loads the power block down, shutting off the power light.
Or....something has been damaged inside the laptop. Pull the cord from the laptop and see if you get the same results.
zappa is offline   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 02:47 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
