Acceptable Way To Ground Metal Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-13-2012, 12:44 PM   #1
Acceptable way to ground metal box?
Hello all,
Is this an acceptable way to ground a metal box, by looping the main green wire around the green screw as that wire enters the box? (as shown in the picture) Or is it more correct to just run a pigtail to the green screw? With the method I've shown, it saves me from making another pigtail, and then it's easier to twist, say, three wires in a wire nut instead of four.
http://postimage.org/image/j2ll14jiv/
Any reason why this method is wrong or a bad idea? Thanks.
bottlerockett is offline   Reply With Quote
Old 05-13-2012, 12:58 PM   #2
Code05's Avatar
Rewards Points: 1,104
It is fine as long as the wire is not crossed under the screw, that would be a bad connection and damage the ground wire. Maintain a tight U shape.
Code05 is offline   Reply With Quote
Old 05-13-2012, 01:03 PM   #3
so you're saying, as long as the ground wire doesn't touch itself as it loops around the screw?
Just curious, why would that make a bad connection, if the ground wire touches itself?
Also, is this the way an electrician would ground a box, or would he use a pigtail? thanks again.
Don
Old 05-13-2012, 01:08 PM   #4
Rewards Points: 1,440
You can loop it around the screw and, instead of crossing over, the wire bends back the other way and continues on to something else. Some folks call that an omega shaped loop. The wire must not be bent too sharply, thr bending radius around the screw is a good enough minimum to go by.
Wrapping around a screw and then continuing to something else is not that common because most of the time the ground wire end is not long enough.
Old 05-13-2012, 01:22 PM   #5
OK, so then the way I've looped the wire in the picture would not be ideal, since the wire crosses over and is bent farther than a U shape.
I can understand that bending the wire too far might make it brittle, but does it create a safety hazard in some other way? thx.
Old 05-13-2012, 02:04 PM   #6
The "bad" connection is because the screw hits and tightens on the spot where the wires cross and does not contact the rest of the loop. The connection is not "that" bad. The problem is that the wire gets crushed where it crosses and after years of vibration from trucks passing on the street outside, the wire could break.
Simply bending the wire farther than a U shape does not weaken it, it is how sharp the crease is.
Old 05-13-2012, 02:59 PM   #7
Code05's Avatar
Actually it is quite common in new construction.
The Following 2 Users Say Thank You to Code05 For This Useful Post:
brric (05-13-2012), k_buz (05-13-2012)
Old 05-13-2012, 03:31 PM   #8
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I usually just use a scrap piece of bare or green insulated wire to go to the screw then wire nut all the grounds together. But I have done it both ways.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-13-2012, 05:04 PM   #9
Sparky
Rewards Points: 510
if i'm running the cables, i try to do just this.
but i'll use a pigtail if necessary
Techy is offline   Reply With Quote
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
Ground wire connections in metal junction box. Jim F Electrical 16 03-03-2011 12:13 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
GROUND - Wall Oven - Water Line Acceptable? Mickey53 Electrical 5 09-29-2008 01:02 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
