Forums | Home Repair | Home Improvement | Painting | Interior Decorating | Remodeling | Landscaping
Old 09-05-2012, 08:08 AM   #1
Share |
Acceptable solution for 4 way UF splice
Hi all,
I am moving a lamp post, which to my surprise had 3 wires spliced together in the post - which feed other outdoor landscape lighting (all line voltage).
Because the UF splice kits are for one cable, the only solution I could come up with is to use an underground junction box (the fiberglass 8-10" round type that looks like an upside down flower pot) with a bolted cover, exposed to surface. The wires would be splices here (I need to add one to extend the lampost), soldered, water resistant wire nuts, then coated with liquid elec tape. The J Box would be set in gravel to ensure drainage.
Is this OK or is there a better way?
Thanks in advance!
raybo is offline   Reply With Quote
Old 09-05-2012, 10:47 AM   #2
You can use a hand Hole for the connections. They sell wire nuts made for connections like this.
Old 09-05-2012, 10:57 AM   #3
liscenced electrician
Agreed. Put some sort of access and just use wirenuts. Preferably wet location rated ones but I think you'd be fine to use regular wirenuts if you put a squirt of deox in each one. Electrical tape them with some 33 if you want but I wouldn't use liquid tape. Twist the wires together before you nut them
jimmy21 is offline   Reply With Quote
Old 09-05-2012, 07:59 PM   #4
E2 Electrician
stickboy1375's Avatar
You have to use listed wirenuts for this application.
stickboy1375 is online now   Reply With Quote
Old 09-05-2012, 08:02 PM   #5
E2 Electrician
I use these, 15-20 bucks price range...
Underground wirenuts.
http://www.landscapelightingworld.co...tCode=9-hubbox
Old 09-05-2012, 08:41 PM   #6
Thanks for your comments and support - I went to my local elec supply and they had the exact same handhole that stick boy pictured.. I did use the gel filled blue waterproof wirenuts - went a step further and twisted and soldered too - unnecessary, I know, but weather does funny things to stuff over time..
Old 09-06-2012, 09:39 PM   #7
E2 Electrician
Some good examples of BAD installations...
Old 09-07-2012, 04:41 AM   #8
Yuckers....how would one prevent that?
zappa is offline   Reply With Quote
Help trying to identify Main Panel circuit breaker Interlock solution Linos Electrical 9 05-16-2012 04:00 PM
Splice an Underground wire for light post rpearlberg Electrical 23 11-21-2011 05:49 PM
splice in electrical box dmilne Electrical 2 02-25-2010 10:59 AM
to splice or not to splice treedoc Electrical 4 01-19-2008 10:56 PM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 02:21 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
