Acceptable Routing - Electrical - DIY Chatroom Home Improvement Forum
Old 05-07-2008, 08:32 AM   #1
Rewards Points: 270
Acceptable routing
I need to run a line from the attic down to the kitchen for a dishwasher. Our top cabinets have mouldings which go to the ceiling and the mouldings are not on yet. Rather than trying to drill a hole through the header which is very difficult to access, then go directly down behind the wall, can I drill a hole in the ceiling above the cabinet, where the moulding will be later covering entirely, then into the wall and down? I was planning on using MC 12/2 with separate green ground wire.
pcampbell is offline   Reply With Quote
Old 05-07-2008, 05:53 PM   #2
Rewards Points: 270
No comments ???
Old 05-07-2008, 06:24 PM   #3
Master Of Nothing
mr500's Avatar
yes. 12-2 W/ground will be ok.(all 3 wires in same sheathing) Just curious as to why your coming from the attic??
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
mr500 is offline   Reply With Quote
Old 05-07-2008, 06:35 PM   #4
Rewards Points: 270
My concern was the routing... going through the ceiling, then through wall as opposed to through the header in which case it would all be behind the wall.
The basement is finished unfortunately and I believe I would have make many holes in the ceiling to come from below. Have to go from one end of the basement to the other and the joists run perpendicular.
Old 05-07-2008, 07:00 PM   #5
Master Of Nothing
mr500's Avatar
I don't think what you want to do violates any codes. But then I don't have them all memorized either lol. Way I see it once you put up the molding you wont even see the cable. Are you using 12-2 w/ground?. Will be 3 wires blk,wht,and green all in same sheathing. I know you mentioned a separate gnd wire. Did not know if that meant you were running a ground by itself. as opposed to it being in the sheathing with the 12-2
Just my 2 cents
Old 05-07-2008, 07:28 PM   #6
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Code does not permit you to run a separate ground wire outside the MC. Some MC sheath is listed and approved as the equipment ground. Check yours. The path you wish to take with it is no problem.
John
jrclen is offline   Reply With Quote
Old 05-07-2008, 07:50 PM   #7
Rewards Points: 270
It's MC with 3 including green ground within the armor. Sorry for the confusing description. What I meant by separate was that it had a ground wire as opposed to the sheathing being the ground. Thanks.
Old 05-08-2008, 09:02 AM   #8
jrclen's Avatar
Rewards Points: 514
Ok, then you have no problem with your plan.
John
Can I get some help with a routing problem? Bun Carpentry 6 04-15-2008 01:17 PM
routing cables through walls and attics cannouu Electrical 18 04-10-2008 07:53 PM
Routing DC wiring Alpha Crow Electrical 2 09-27-2007 05:25 PM
Determining drain pipe routing? tigerbalm2424 Plumbing 3 03-09-2007 09:12 AM
Roof Sheathing Acceptable Tolerances? claypj Roofing/Siding 2 08-15-2005 04:16 PM
