Acceptable Method For Outlet Location - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2012, 08:06 AM   #1
langless28's Avatar
Rewards Points: 152
acceptable method for outlet location
for a outlet in a cabinet (specifically the microwave).
with the wire pre-placed in the wall and the drywall and cabinets up, can you cut through the backside of the cabinet and drywall and install an old work box flush with the inside back cabinet face? is that ok for a outlet for the gd/dw under the cabinets as well?
langless28 is offline   Reply With Quote
Old 10-22-2012, 08:37 AM   #2
Rewards Points: 6,652
Overly discussed topic on here.
Old 10-22-2012, 08:47 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
That is fine.
Old 10-22-2012, 10:38 AM   #4
langless28's Avatar
Rewards Points: 152
thanks, i figured it was a common question but not a whole lot came up with the search terms i used.
Old 10-22-2012, 10:43 AM   #5
Rewards Points: 13,300
Easyest, most accurate, safest way to cut the hole would be with an ossilating saw.
Old 10-22-2012, 10:45 AM   #6
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Oldwork is fine and does not require GFI protection.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Where to attach Fresh Air intake location on return plenum Haggis HVAC 25 09-25-2012 07:18 PM
Need help choosing the easiest method for skim coating fortunecookies Drywall & Plaster 2 03-05-2011 04:09 PM
Proper method for well pump wires coming through wall theedudenator Electrical 3 02-11-2010 12:10 AM
Over 8 Foot Wall - Method of Applying Sheathing... MoparAutoworks Building & Construction 14 08-20-2006 08:38 PM
