Old 08-05-2012, 07:51 PM   #1
ac wiring problems
my dog ate the wiring from the thermostat control to the ac unit outside can anybody give me a hand reparing it? thankyou M
mjpernetti is offline   Reply With Quote
Old 08-05-2012, 07:54 PM   #2
Licensed Electrician
k_buz's Avatar
ac wiring problems
Buy some TStat cable with the same number of conductors, make a note of where each color is terminated on each end. Replace wire.
Location...Location...Location
Old 08-05-2012, 08:11 PM   #3
ac wiring problems
K_buz Thankyou the wiring is only broken at the end where it comes out of the house to the ac unit, i have 4 wires at the house opening blue, white, red, green. comming from the ac unit they are 1 blue and 1 yellow.
Old 08-05-2012, 08:57 PM   #4
Missouri Bound's Avatar
ac wiring problems
You will need to open up the control panel on the condensor and see which wires are used. You still need to replace the entire wire.
Do you want it your way or the right way?
Old 08-05-2012, 09:01 PM   #5
ac wiring problems
on the ac unit there are 2 wires one blue and one yellow, fromthe house out to the ac unit there are 4 wires. blue, red, white, green.
heat pump wiring problems zskyman HVAC 17 07-26-2012 05:55 AM
Wiring Problems? Zacariah HVAC 1 10-30-2010 07:20 PM
Knob and Tube wiring. bronco2 Electrical 8 10-03-2009 01:36 PM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
