Old 07-05-2011, 10:16 PM   #1
AC Plugs
I need help. I am installing a new AC unit. The current plug is like this l -- but the plug for the new AC is -- -- both are 15 amp.. Can a new plug be installed?
Thanks in advance.
capt2 is offline   Reply With Quote
Old 07-05-2011, 10:24 PM   #2
Licensed electrician
AC Plugs
Your new AC requires 240 volts. the old receptacle is 120 volts.
If this is a dedicated circuit you should be able to rewire.
Old 07-05-2011, 10:25 PM   #3
Mad Scientist
AC Plugs
The new plug is a 15A 240V plug, and the old is either a 20A 120V plug or 20A 240V plug. Are those diagrams showing what the plug looks like pointing at you, or what the receptacle would look like?
McSteve is offline   Reply With Quote
Old 07-05-2011, 10:44 PM   #4
AC Plugs
Thank you for the replies. Let me re check and I'll post back.
'06 Impala - how to change spark plugs + gap spec. DIYguy2000 Automotive Repairs 0 06-20-2011 10:26 AM
cutting plugs off would violate... Daneel Electrical 9 06-05-2011 05:21 AM
Pigtails on plugs? brons2 Electrical 6 05-24-2011 01:22 PM
GFCI plugs in kitchen DeterminedMom Electrical 10 04-23-2009 11:42 PM
KO plugs are dangerous! KE2KB Electrical 10 11-25-2008 07:57 PM
