AC And Old Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 07:51 PM   #1
Rewards Points: 14
AC and old wiring
I would like to get a window AC unit but I am not sure if my wiring is ok. I have an old house that has some knob and tube left in it. I had the panel upgraded and there is new wiring in the house also. I have receptacles that are all three prong but that dosn't mean anything. My question is if I plug in an ac and it is old wiring will something really bad happen or will I just trip the breaker?
needtoknow is offline   Reply With Quote
Old 07-05-2010, 08:25 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
As long as there is nothing defective with the wiring, if you overload the circuit, the breaker will trip. That is what they are supposed to do.
Old 07-05-2010, 08:56 PM   #3
What size AC ?
Has the K&T been inspected recently ?
Any problems with it ?
Old 07-05-2010, 09:10 PM   #4
Rewards Points: 14
I just want a small ac maybe 5000 btu. Nothing is wrong with the wiring it checked out fine.
Old 07-05-2010, 09:33 PM   #5
I have a 14k btu AC that can run on a 15a circuit
I have seen 5k btu AC's around 5a = 600w
That's less then my toaster (850w)
Old 07-05-2010, 09:51 PM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
You should be fine, but if you really want to be safe and your basement is not done, you can always install a new outlet and fish the wire down.
That's what I did for my portable AC which is rated at 14.5 amps. So I installed a 20 amp outlet.
