AC Disconnect Switch - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 09:35 PM   #46
" Euro " electrician
frenchelectrican's Avatar
Bonjour SirSparkalot.,
If ya have time or something will you find something to cover that hole of the meter box on the right side otherwise some dolts will stick the finger and light them up themself.
Now let get to the main point :
This what I useally do in here ( France ) size the OCPD ( breaker or fuse ) to the max as the nameplate call and run the conductor ( wire or cable ) on minuim size per nameplate specs.
I know it is simair over there in USA / Canada side.
But for the rest of the details the other guys allready got the answer for ya.
Merci,
Marc
Old 04-21-2013, 09:37 PM   #47
Rewards Points: 506
Merci,
Marc
Thanks, Marc. Yes, that hole has been taken care of.
I'll have to see what the specs are tomorrow.
Installation is the Reverse of Removal.
Old 04-21-2013, 10:51 PM   #48
Licensed electrician
Rewards Points: 1,038
That disconnect is just a pullout, there are no places for fuses.
Old 04-22-2013, 12:16 AM   #49
joed's Avatar
Rewards Points: 11,598
We have not seen the handle yet and the box says fusible.
Old 04-22-2013, 04:08 AM   #50
Electrical Contractor
kbsparky's Avatar
Go back and look at post #29 in this thread and then tell me this again.
-KB
Old 04-22-2013, 05:07 AM   #51
I have seen the packages switched at the stores frequently. I don't believe the box. That is the style I use.
Old 04-22-2013, 06:18 AM   #52
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I use the same disconnect as well, and have never seen one that allowed fuses in the handle, so I'm confused.
Old 04-22-2013, 06:41 AM   #53
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Although I have never used or seen one like that, I see big orange does sell them.
Old 04-22-2013, 07:09 AM   #54
Rewards Points: 2,512
Yeah big orange carries them. Says requires 2 fuses installed on the back side of the puller.
On the review page the question is asked about the fuses.
Answer is:
it includes the Pull out, but does not include the fuses, which need to be selected based on the requirements of the circuit in which it's installed.
hammerlane is offline   Reply With Quote
Old 04-22-2013, 02:58 PM   #55
Rewards Points: 506
Answer is:
What a man!
Now I only need to learn to read!
Old 04-22-2013, 03:35 PM   #56
jbfan's Avatar
Rewards Points: 144
Originally Posted by sirsparksalot View Post
What a man!
I would eat that money spent on the disconnect and buy one that does not have to have fuses in the handle.
I'm sure most of us would have had a head scratching moment if you still did not have the box.
The Following User Says Thank You to jbfan For This Useful Post:
stickboy1375 (04-22-2013)
Old 04-22-2013, 04:36 PM   #57
Oso954's Avatar
Rewards Points: 442
I don't think it has the fuses in the handle. The handle in the HD photo is too small to carry 2 cartridge fuses. I believe that description was pulled from the TF30R. (SirSparks, the item you should have received is a Model TF30RCP if you have not noted that yet.)
The fuses should be below the black panel with the label.
I'd take the disconnect and the box back to HD and tell them they supplied the wrong product. (Non-fusible instead of fusible)
Here is a pic of the handle used by the GE "fuse in back of handle".
Oso954 is offline   Reply With Quote
Old 04-22-2013, 04:41 PM   #58
k_buz's Avatar
The fuses sit horizontal in this model, not vertical like in the picture you show.
Old 04-22-2013, 05:29 PM   #59
E2 Electrician
I didn't even know such a beast existed...
Old 04-22-2013, 06:47 PM   #60
Wish the poster would just post some close up photos of the handle.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Disconnect equipment switch agent99 Electrical 7 06-30-2012 01:52 PM
How to disconnect an outlet from a light switch mattjarvinen Electrical 2 08-26-2011 12:53 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
