AC Disconnect Switch - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 07:45 PM   #31
Electrical Contractor
kbsparky's Avatar
Originally Posted by stickboy1375 View Post
Do we know the specs on the AC unit? 30 amps may trip when the unit starts.
30 is the largest fuse that can fit in this disconnect box. IF they blow, then a non-fusible disconnect switch will have to be installed, or dummy fuses installed.
My experience is that dummy fuses are more expensive than a non-fusible disconnect.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
sirsparksalot (04-21-2013)
Old 04-21-2013, 07:46 PM   #32
Rewards Points: 512
No, I don't have any specs right now, but the breaker held, and the fuses didn't blow.
Installation is the Reverse of Removal.
Old 04-21-2013, 07:47 PM   #33
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I want to see the specs on the AC unit now...
Old 04-21-2013, 07:47 PM   #34
E2 Electrician
The nameplate on the AC unit will tell you everything you need to know... how did you size the 10-2 to the DISCO without specs?
Old 04-21-2013, 07:49 PM   #35
Rewards Points: 512
Well, CRAP!
How 'bout tomorrow, same battime, same batchannel?
Old 04-21-2013, 07:49 PM   #36
E2 Electrician
Well, CRAP!
awesome...
just take a picture of it.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 04-21-2013, 07:49 PM   #37
Rewards Points: 512
I went by the existing install.
Old 04-21-2013, 07:51 PM   #38
E2 Electrician
So basically, you just replaced the disco? You really need to address the wiring method going from the DISCO to the AC unit.. it wont burn the house down, but since you went this far, might as well fix the rest of the job.
Old 04-21-2013, 07:52 PM   #39
Rewards Points: 512
hang on just a sec, I'm gonna look fer sumptin'
Old 04-21-2013, 07:55 PM   #40
Rewards Points: 512
well, chit, again, didn't find what I wanted, but the "wiring method" was simply 10-3 from disco to AC. No Carflex or whip, just Romex.
Old 04-21-2013, 07:57 PM   #41
E2 Electrician
Romex ( NM type wiring) is only good for dry locations. no good outside... either replace it with UF or more commonly carflex and thwn is used.
Old 04-21-2013, 07:58 PM   #42
Rewards Points: 512
Of course, I didn't get any after-shots, but here's some befores You'll have to trust that they're pretty NOW.
Old 04-21-2013, 08:02 PM   #43
Rewards Points: 512
Don't know how much you can tell about the AC from the one far-away shot.
AC Disconnect Switch-garage_laundryrm.jpg   AC Disconnect Switch-picture-025.jpg   AC Disconnect Switch-picture-029.jpg
Old 04-21-2013, 08:03 PM   #44
Rewards Points: 512
OK, I'll check that out for sure.
Old 04-21-2013, 08:04 PM   #45
E2 Electrician
You dont have to jump on it, just put it on your list of items to address.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Disconnect equipment switch agent99 Electrical 7 06-30-2012 12:52 PM
How to disconnect an outlet from a light switch mattjarvinen Electrical 2 08-25-2011 11:53 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
