AC Disconnect Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 04:28 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by joed View Post
we need a picture of the handle. If it was fusible the fuses would be in the handle. The contacts in the handle are going to be on side. When you plug handle back in make sure the contacts are down to make the connections.
Its a non fusible disconnect.
Old 04-21-2013, 04:30 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Those connecters are not for outdoor use.
The Following User Says Thank You to k_buz For This Useful Post:
sirsparksalot (04-21-2013)
Old 04-21-2013, 04:30 PM   #18
E2 Electrician
neither are most NM connectors, but they get used all the time... I personally don't have an issue with it.
Old 04-21-2013, 04:38 PM   #19
Originally Posted by Oso954
Look at the clips that the "handle" slides into. The line clip on the extreme right is bent. It appears to be bent enough to explain why you don't have that phase.
Yep that is what i noticed as well.
Focused2 is offline   Reply With Quote
Old 04-21-2013, 07:20 PM   #20
Rewards Points: 512
Fusible Disco. Wonder why they don't come with the package
Installation is the Reverse of Removal.
Old 04-21-2013, 07:27 PM   #21
E2 Electrician
where did you get that disco from?
Old 04-21-2013, 07:29 PM   #22
Rewards Points: 512
Originally Posted by stickboy1375 View Post
What type of wiring method is supplying the AC unit?
Well, that's a great question. It is 10/3 with the white equipment grounded (just made that term up going to a screw on the frame with a bare)
The primary side is fed from a 30amp 10-2 (I did this).
I looked at the label on the AC and it indicated nothing about needing 120, rather, it stated 220v, but upon firing it up, the fan spun once, and stopped, so now I'm not sure that 120 isn't needed for either the fan, or some other purpose. BUT, why would the white wire terminate on the frame if it is meant to be a neutral? I seen no indication on the inside of the unit that a neutral was needed.
BTW: I terminated the white from the AC unit to the Disco to the ground bar. ?????
Old 04-21-2013, 07:29 PM   #23
Rewards Points: 512
Home Depot
Old 04-21-2013, 07:30 PM   #24
E2 Electrician
You cant use that wiring method outside...
The AC unit is 240v.... you cant have the white and ground landed together, just cap off the white conductor. In the future, just lower the AC disconnect and have your cable enter the back of the disconnect, this will neaten up your install.
Old 04-21-2013, 07:30 PM   #25
E2 Electrician
Home Depot
I'm surprised they sell a fusible disconnect. i've never seen one required in the residential field.
Old 04-21-2013, 07:35 PM   #26
Rewards Points: 512
the box here
Old 04-21-2013, 07:39 PM   #27
Rewards Points: 512
The white (from the AC unit) isn't live or in use, it's just an extra wire.
Thanks, I agree. I just used the same hole that the old Disco was using.
Old 04-21-2013, 07:40 PM   #28
E2 Electrician
I know, just cap it off on each end.
Old 04-21-2013, 07:41 PM   #29
Electrical Contractor
kbsparky's Avatar
Needs fuses, or else nothing will work. You'll have to buy a couple of 30 Amp cartridge fuses for this disconnect.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Old 04-21-2013, 07:43 PM   #30
E2 Electrician
Do we know the specs on the AC unit? 30 amps may trip when the unit starts.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Disconnect equipment switch agent99 Electrical 7 06-30-2012 12:52 PM
How to disconnect an outlet from a light switch mattjarvinen Electrical 2 08-25-2011 11:53 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
