AC Disconnect Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 02:44 PM   #1
Rewards Points: 512
No voltage on the LOAD terminals on this GE Model GEH-5886
The LINE terminals are the two outside ones, while the LOAD are the two inside ones.
Any thoughts?
Installation is the Reverse of Removal.
Old 04-21-2013, 03:01 PM   #2
joed's Avatar
Rewards Points: 13,354
No fuses?
Pull the handle and show us the insides.
I see an On OFF on the handle. Does pulling it and turning over turn it on?
Old 04-21-2013, 03:04 PM   #3
Rewards Points: 512
tried both ways, no voltage. Does it look to you that it's currently OFF?
Old 04-21-2013, 03:08 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Some of those can be a little finicky, make sure it is pushed in all the way. It appears that you have it the correct way, but you can try both ways. Also, make sure you have voltage on the line side to make sure you aren't chasing the wrong problem.
Old 04-21-2013, 03:08 PM   #5
joed's Avatar
Unless it is mounted upside down then since ON is readable I would say it is on.
What about fuses inside?
Old 04-21-2013, 03:10 PM   #6
Rewards Points: 512
220 on LINE, 120 between ground and each phase
Old 04-21-2013, 03:10 PM   #7
Rewards Points: 512
The breaker is new; just installed.
Old 04-21-2013, 03:17 PM   #8
Oso954's Avatar
Rewards Points: 1,338
I think joed is asking if that might be a fusible disconnect. If so, it needs fuses before you have power on the load.
Oso954 is offline   Reply With Quote
Old 04-21-2013, 03:20 PM   #9
Rewards Points: 512
Where would the fuses go?
Old 04-21-2013, 03:39 PM   #10
Oso954's Avatar
Don't worry about it. I found a reference that says it is a non-fusible 60 amp pull out.
Old 04-21-2013, 03:43 PM   #11
Rewards Points: 512
here's w/ handle removed
Old 04-21-2013, 03:44 PM   #12
Rewards Points: 512
it's a 30-amp
Old 04-21-2013, 03:58 PM   #13
joed's Avatar
we need a picture of the handle. If it was fusible the fuses would be in the handle. The contacts in the handle are going to be on side. When you plug handle back in make sure the contacts are down to make the connections.
The Following User Says Thank You to joed For This Useful Post:
sirsparksalot (04-21-2013)
Old 04-21-2013, 04:23 PM   #14
Oso954's Avatar
Look at the clips that the "handle" slides into. The line clip on the extreme right is bent. It appears to be bent enough to explain why you don't have that phase.
Old 04-21-2013, 04:27 PM   #15
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
What type of wiring method is supplying the AC unit?
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Disconnect equipment switch agent99 Electrical 7 06-30-2012 12:52 PM
How to disconnect an outlet from a light switch mattjarvinen Electrical 2 08-25-2011 11:53 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
