-   -   AC Disconnect Switch (http://www.diychatroom.com/f18/ac-disconnect-switch-177752/)
sirsparksalot 04-21-2013 03:44 PM
1 Attachment(s)
No voltage on the LOAD terminals on this GE Model GEH-5886
The LINE terminals are the two outside ones, while the LOAD are the two inside ones.
Any thoughts?
joed 04-21-2013 04:01 PM
No fuses?
Pull the handle and show us the insides.
I see an On OFF on the handle. Does pulling it and turning over turn it on?
sirsparksalot 04-21-2013 04:04 PM
tried both ways, no voltage. Does it look to you that it's currently OFF?
k_buz 04-21-2013 04:08 PM
Some of those can be a little finicky, make sure it is pushed in all the way. It appears that you have it the correct way, but you can try both ways. Also, make sure you have voltage on the line side to make sure you aren't chasing the wrong problem.
joed 04-21-2013 04:08 PM
Unless it is mounted upside down then since ON is readable I would say it is on.
What about fuses inside?
sirsparksalot 04-21-2013 04:10 PM
220 on LINE, 120 between ground and each phase
The breaker is new; just installed.
Oso954 04-21-2013 04:17 PM
I think joed is asking if that might be a fusible disconnect. If so, it needs fuses before you have power on the load.
sirsparksalot 04-21-2013 04:20 PM
Where would the fuses go?
Oso954 04-21-2013 04:39 PM
Don't worry about it. I found a reference that says it is a non-fusible 60 amp pull out.
sirsparksalot 04-21-2013 04:43 PM
1 Attachment(s)
here's w/ handle removed
sirsparksalot 04-21-2013 04:44 PM
it's a 30-amp
joed 04-21-2013 04:58 PM
we need a picture of the handle. If it was fusible the fuses would be in the handle. The contacts in the handle are going to be on side. When you plug handle back in make sure the contacts are down to make the connections.
Oso954 04-21-2013 05:23 PM
Look at the clips that the "handle" slides into. The line clip on the extreme right is bent. It appears to be bent enough to explain why you don't have that phase.
stickboy1375 04-21-2013 05:27 PM
12 Attachment(s)
http://www.diychatroom.com/attachmen...ch-acdisco.jpg
What type of wiring method is supplying the AC unit?
