AC To DC Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 06:00 PM   #1
AC to DC needed
. I need to be able to power some lights on a car using AC power. i will need appx 85 amps of DC power. I need to find the least expensive method. this power will need to run sometimes 16 hours at a time. i hope someone can lend a great suggestion. Thank you!
92Ecto is offline   Reply With Quote
Old 12-30-2012, 06:05 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 818
Least expensive? Car battery with a charger hooked up to it.
Any reason you can't change the bulbs to AC?
Old 12-30-2012, 06:10 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,098
a 1000w tranny is not going to be cheap !
But they are available.
What type of lights are they !
If they are just incandesant, then they
will work quite happily on 12vac.
So you dont need a filter cap.
dmxtothemax is online now   Reply With Quote
Old 12-30-2012, 06:13 PM   #4
85 amps for 16 hours !
thats 1369 AH'S
Most car batteries deliver 50 to 100 AH's.
NO CHANCE.
Old 12-30-2012, 06:13 PM   #5
The lights are 55watt halogen..2 light bars with a total of 17 lights and rotators. So no..cannot change out the bulbs
Old 12-30-2012, 06:16 PM   #6
plus a Strobe bar with 2 15amp relays. to give Precise info, 2 Code 3 MX7000 light bars and 1 Whelan Edge 9000 strobe bar.
http://www.facebook.com/photo.php?fb...1949634&type=1
Old 12-30-2012, 06:18 PM   #7
Old 12-30-2012, 06:36 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
1200 watt landscape lighting transformer will deliver 100 amps at 12 volts. Not cheap but you can get one on eBay for $600.
Coastal South Carolina
Old 12-30-2012, 06:48 PM   #9
Semi-Pro Electro-Geek
Rewards Points: 2,858
There are plenty of Chinese vendors selling 100A 12V switching power supplies through AliExpress. Quality varies, as does the customer service experience. I've ordered plenty of stuff through them and it usually works out acceptably. If I needed a power supply like that right now, that's how I'd get it. Be aware that delivery usually takes about a month.
http://www.aliexpress.com/wholesale?...=y&needQuery=y
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 12-30-2012, 06:54 PM   #10
Switching power supply, Would be same as a PC Power supply? If i have 3 that carry the needed amerage, could i hook up the 3 PC Power supplies to run the units?
Old 12-30-2012, 07:43 PM   #11
You should not parrallel power supplies !
But there'es no reason why you cant just have
the load divided up amongst 3 or 4 supplies.
this would be cheaper and easier.
Old 12-30-2012, 07:50 PM   #12
Thats Exactly what i meant. Use 3 Computer power supplies, to power the 3 light bars. I was hoping this would work, but wasnt certain. Thank you!
Old 12-30-2012, 09:02 PM   #13
Master Electrician
Rewards Points: 3,678
DC to AC requires an inverter. You already have DC in the vehicle.
brric is offline   Reply With Quote
Old 12-30-2012, 10:31 PM   #14
Mad Scientist
What's your overall goal here? "92Ecto" -- Are you by chance one of the replica Ghostbusters vehicle guys?
McSteve is offline   Reply With Quote
Old 12-31-2012, 05:05 AM   #15
I am aware of this, Tis why i said " I need AC to DC"
Replacing rooftop deck - permit needed? esk8mw Building & Construction 5 01-27-2012 03:02 AM
Fan size needed for Spray Booth (CFM) Sandy 1150 Painting 0 12-21-2011 08:22 PM
Building a 20' x 20' wood frame garage bgbrown125 Building & Construction 38 08-07-2011 02:53 PM
Face nail needed with Bona r851? bakerzdosen Flooring 0 08-01-2011 08:56 AM
Tankless Waterheater recomendations Needed! (please) fremault Plumbing 7 01-27-2008 03:00 PM
