AC Breaker Trips On Generator - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 06:48 PM   #16
An old Tradesmen
Rewards Points: 6,476
Originally Posted by stickboy1375 View Post
a 5 ton unit is WAY over a 7 kw generator, I have a 3 ton unit and a 7kw generator and it won't start it...
Do you have a hard start kit on the condenser?
Old 07-09-2012, 06:51 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
No, I don't, but seriously, I'm already drawing 12-15 amps with just the house, so no way I'm i going to fire off a 3 ton unit. I have a 2 stage heat pump by the way, and last winter storm I wanted to try and use it just out of curiosity, hate burning oil.
Old 07-09-2012, 06:53 PM   #18
An old Tradesmen
For the heck of it, install a hard start kit on the compressor and try it. The hard start kit will help the compressor start under normal operation no matter what, so its not a waste of money.
Old 07-09-2012, 06:56 PM   #19
E2 Electrician
If these things are so great, why don't they come pre equipped with every unit right out of the factory? Im a little sepecious of these kinds of items.
Old 07-09-2012, 07:19 PM   #20
An old Tradesmen
One very simple reason. MONEY. The manufacturers save money by not putting them in every unit they make. however, many of the highest end units do come with them installed from the factory.
A hard start kit doesn't lower the amp draw of start up. It does however decrease the amount of time it takes to get the compressor moving. It decreases it so much. That many techs using standard meters that don't respond very fast, only see a small amount of the actual amp draw on their meters, and think it decreases amp draw.
The Following User Says Thank You to beenthere For This Useful Post:
zappa (07-10-2012)
Old 07-09-2012, 07:28 PM   #21
An old Tradesmen
Also. On another web site. A poster said his 2.5 ton wouldn't start using his XG8000E Generac. He put a har start on and it started it. he also found his unit had one from the factory. But it had burned out sometime before he connected the A/C to the gennie. And that is why it wouldn't start originally.
Old 07-10-2012, 02:49 AM   #22
How about this: Install a shaft extension on the A/C compressor. Couple the extension to gearing, and a pressure clutch. Rig up one of those exercise bicycles to the gearing, clutch and shaft extension.
Git the wife on that there bicycle when it's hot and humid outside, and git her to peddlin' like a bat-outta-Hell, (or like your mother-in-law, that is...): Rig up a centrifugal bell-ringer, and a remote clutch-engagement release, and generator starter.
When the bell rings, engage the clutch, and seconds later remotely start the generator. Change the channel, and crack another cold 'un...why, the wife's loosin' weight...and its gittin' cooler by the mo'. Who need a hard start...?
kontoose is offline   Reply With Quote
Old 07-10-2012, 08:57 AM   #23
..and put the video of it on youtube!
Auger01 is offline   Reply With Quote
Old 07-11-2012, 01:25 AM   #24
Here, here...!
Old 07-11-2012, 01:26 AM   #25
Old 07-11-2012, 01:30 AM   #26
Old 07-11-2012, 04:34 PM   #27
I will be contacting my local HVAC supply houses, but what guidelines and data should I use for selecting a hard start kit for my particular 2.5 ton central AC?
My surge is about 4-1/2 times normal draw.
If I get a 5 kw portable gen that can run my central AC, this would be very good news. Without the kit it looks like a 14 to 20 kw gen.
The min operating voltage is on the nameplate. If I hook up the gen with a skinny cord I will reduce both surge and steady-state current.
Thanks, BT. . .
Old 07-11-2012, 04:46 PM   #28
An old Tradesmen
CSR U1, although I've used the U2 on 2.5 tonners a few times now.
Old 07-12-2012, 03:49 AM   #29
No...(heehee): Don't use a "skinny cord"! That is exactly the opposite of the remedy of the source problem here...
Old 07-12-2012, 09:16 AM   #30
What made you decide either way, U1 or U2? Is there no disadvantage to using the U2 on the smaller ACs? The price seems to be same, either way.
I'm not so sure.
You have the generator transient response, the AC transient current demand vs. duration, the line resistance including the cabling and whatnot, and the service lifetimes of the gen and AC, and these are all interdependent.
Adjusting the series resistance may be an option, depending on what minimum line voltage is spec'd for the AC.
If my o'scope still works, and if I can find my 0.01 ohm shunt, I'll have to see what kind of starting transient current my AC pulls, and the waveshape (which I assume is an exponentially damped sine wave).
Adding 220 20A breaker but it trips when turned on mi_fiveo Electrical 23 05-19-2012 12:46 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 12:23 PM
New pool pump trips breaker?! New home owner needs advice. KenR7A Electrical 22 01-05-2011 10:42 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Central Air Trips Breaker RobSmith HVAC 6 08-05-2008 10:06 AM
