Ac Breaker Outside Has Burning Smell Coming From It - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 02:00 AM   #1
ac breaker outside has burning smell coming from it
what do i do and how much will it coast to fix it
hawkeyes20 is offline   Reply With Quote
Old 09-27-2011, 04:50 AM   #2
Rewards Points: 1,192
Might be loose connection,causing wire to heat up.
bobelectric is offline   Reply With Quote
Old 09-27-2011, 07:30 AM   #3
This is probably a simple fix, to tighten or to replace, if you know how. Your question suggests you don't know how, so leave it to a pro. You can get dead with one slip.
Old 09-27-2011, 07:34 AM   #4
dmxtothemax's Avatar
Rewards Points: 5,106
Most likely a faulty / loose connection !
Or a faulty breaker !
If you are not confident enough to fix it !
Turn off the faulty breaker, so you dont burn the house down,
And call an electricain in .
dmxtothemax is online now   Reply With Quote
Burning smell from vents when ac turns on noone HVAC 15 07-30-2011 02:23 PM
Burning smell coming from vent in my childs room joy@wholfit HVAC 4 03-04-2011 02:28 AM
Mold smell in AC houndog HVAC 4 06-03-2010 07:27 PM
Lennox 10acb24 - 11P Burning Smell pchangela HVAC 3 08-17-2009 09:42 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 09:29 AM
