AC Adapter Question (polarity) - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 03:35 AM   #1
Rewards Points: 43
AC adapter question (polarity)
Hey, so I have a keyboard I want to power via an AC adapter, so medium story short, the back of the keyboard has the Centre positive symbol (http://en.wikipedia.org/wiki/File:Centre-positive.svg), and the adapter has the Centre negative symbol (http://en.wikipedia.org/wiki/File:Centre-negative.svg) (although the centre 'C' is reversed, so the open centre dot goes directly to the + on the left.). See diagram.
Should the polarity symbols match? All other specs are as per the product page/manual (http://www.akaipro.com/mp6-1): 6V DC 1A. Although no mention of the mA's on the adapter.
Oh, and the nib (ending bit of the adapter is yellow, and not black as per the product page linked above).
I sent a message to the manufacturer, but did not include the polarity part. The adapter was from an authorised dealer.
Thanks!
bugmenot is offline   Reply With Quote
Old 03-08-2012, 05:42 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
Your diagram shows the center pole as positive in both situations. Just drawn different. 1A = 1000mA. Reverse polarity will not work in that device and may burn even burn it up.
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
bugmenot (03-09-2012)
Old 03-08-2012, 12:49 PM   #3
Rewards Points: 43
Okay, thanks. It dawned on me the centre tip may be positive, just odd they drew the diagram wrong, err upside down.
On the product page it shows 6VDC @ 500mA's. But on the back of the keyboard it has the 6V DC 1A as I mentioned. Does that mean the adapter cannot exceed 1A?
Old 03-08-2012, 02:58 PM   #4
A 6v, 1A adaptor will probably read 7v with no load which means it's internal resistance is (7-6)v/1A = 1 ohm which means it will supply 2A at 7v-2A(1 ohm)= 5v with a shortened adaptor lifetime.
Some DVMs have a diode test which you can likely use to test proper polarity for your keyboard.
Old 03-08-2012, 04:29 PM   #5
Rewards Points: 43
I don't own a DVM.
Didn't really get the first part, I am far from an expert!
So in regards to the mA, it seems okay to use? (Adapter shown on manufacturer website shows 500mA, this one is 1A.)
Old 03-08-2012, 05:24 PM   #6
Yes.
You ought to buy a meter, it'll pay for itself pretty quickly.
Old 03-09-2012, 02:27 AM   #7
Rewards Points: 43
Thanks for the help!
So out of curiousity, since the one they link to is 500mA, and it asks for 1A, isn't that bad, as the adapter may overheat?
And lastly, some devices can use adapters with reverse polarity?
Old 03-09-2012, 08:07 AM   #8
PoleCat's Avatar
As long as your equipment does not draw more than 1A the power pack will operate within its design range. Many semiconductor devices will not operate right under reverse polarity. Some may even cook.
Old 03-09-2012, 11:29 AM   #9
I'm not sure anymore what to do.
Old 03-09-2012, 02:32 PM   #10
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,186
Your power pack is 500ma and your keyboard needs 1 amp or 1000ma. That's twice what your power pack can supply. You need a bigger power pack. Just go to Wal Mart and get a universal power pack with changeable tips. And pick up a cheap meter while your there. Set the voltage to 6V with the center positive. That would be red lead of tester on center showing 6V and not -6V. Hope this helps.
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 03-09-2012, 03:06 PM   #11
Rewards Points: 43
@shumakerscott My adapter is 1A, but the one recommended (linked) from the product page on the manufacturer's website is a 500mA one. Which I found odd after realising it indeed wouldn't supply enough power.
Old 03-09-2012, 03:28 PM   #12
Dorf dude...
Ok, If you have a 1 Amp adapter, 1000ma and your keyboard needs 500ma then you are good to go . Make sure the center is positive with 6 volts and make music. Your adapter must meet the minimum requirement on amp's but can be larger not smaller. The volts must be the same. dorf dude...
Old 03-09-2012, 05:25 PM   #13
Rewards Points: 43
Thanks, yeah, I am pretty certain I am good to go, just wanted to be 100% sure.
The first post has a diagram I made, and for some reason, I'd say since it was made in China, but probably a lot are made there, but the polarity diagram was upside down.
On a sidenote, the keyboard shows 6V DC 1A, it was the adapter they linked that show 500mA, hence the puzzlement once I realised that. Maybe I'll follow up and ask out of curiousity...
Old 03-09-2012, 05:34 PM   #14
dmxtothemax's Avatar
Rewards Points: 5,108
If the product reccommends a 1000mA supply or 1 A,
Then thats what you should use !
It will probably work with a smaller 500mA supply,
cause it wont pull 1000mA continuously,
only very occassionally.
So under some circumstances you may have problems,
And the life of the smaller supply would be shortened.
dmxtothemax is offline   Reply With Quote
Old 03-09-2012, 07:55 PM   #15
Missouri Bound's Avatar
It's not drawn upside down....you are looking at it upside down. (those symbols, like many others don't have a right side up)
Do you want it your way or the right way?
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 11:18 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
