AC 220 Shut Off? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-02-2012, 01:28 AM   #31
" Euro " electrician
frenchelectrican's Avatar
If my memory serve me right you did have partal phase loss on triphase due I did recall the flourscent luminarie were strobing so I knew what it was and the netural conductor was allready toasted that time. (you may hit a combation of both which it can happened )
Merci,
Marc
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 01:29 AM
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 01:50 AM
Oil Furnace Emergency shut off switch location? LarryNH914 HVAC 19 06-28-2012 03:47 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
