Old 06-25-2011, 01:05 AM   #1
Question
ABS pipe as conduit
I recently finished my basement, including drywalling the ceiling. Before I put up the drywall, I ran a conduit of left-over 2" abs pipe from the electrical panel to the rear of the house. I now want to install a garage at the rear of the house, and I'm wondering if I can use this pipe as a conduit for running the #6/3 wire? Is there anything in the code that might restrict me from using abs pipe for this purpose?
jcvagua is offline   Reply With Quote
Old 06-25-2011, 05:53 AM   #2
Semi-Pro Electro-Geek
ABS pipe as conduit
ABS pipe is not conduit. Conduit is UL listed for that purpose. So, you cannot use ABS pipe in place of conduit. However, you could use ABS pipe as a sleeve to carry a cable that doesn't require conduit, like NM, SE or SER. So you can pull 6/3 NM cable through that ABS sleeve. You'll have to secure it at each end just like if there were no pipe present, but having the pipe there will make it much easier to pull the cable for installation purposes. If an inspector challenges you on this (and they most likely will, if you have it inspected, since pipe is not the same as conduit and no professional would ever do this), they will be unable to cite a code provision that you are actually violating. Even though it's very strange to pull wire through plumbing pipe.
mpoulton is offline   Reply With Quote
Old 06-25-2011, 08:03 AM   #3
Electrician
SD515's Avatar
ABS pipe as conduit
It’s a violation of 110.8 Wiring Methods
“Only wiring methods recognized as suitable are included in this Code. The recognized methods of wiring shall be permitted to be installed in any type of building or occupancy, except as otherwise provided in this Code.
ABS pipe is not recognized in the code as a suitable conduit, therefore it is not allowed to be used for electrical wiring (not even as a sleeve).
Kyle
Old 06-25-2011, 11:04 AM   #4
ABS pipe as conduit
I'm interested to know exactly what provision is violated by using ABS pipe to contain an approved wiring method. Keep in mind that a sleeve is not a raceway, nor is it a part of the "wiring method" - it's simply a location where a wiring method is installed. Where a wiring method is permitted to be used without intermediate support (fished through existing construction, for example), I can see no reason why it could not be installed within an ABS pipe. Installing NM inside an ABS pipe certainly doesn't violate 110.8 as quoted above, provided it's existing construction and the cable is secured at each end as required.
Old 06-25-2011, 12:32 PM   #5
J. V.'s Avatar
ABS pipe as conduit
I agree. There is no violation. "Sleeve" is the keyword, not conduit.
Wait. Is the ABS attached to the panel with a connector? If it is. I am pretty sure it would be a violation.
Old 06-25-2011, 08:31 PM   #6
Missouri Bound's Avatar
ABS pipe as conduit
If the conduit is being used as a "sleeve" or most commonly referred to as a chase, there is no written code violation. However as indicated by J.V, if it is indeed connected to the panel or any box it is a direct violation by using non-permitted materials as conduit.
Tags
#6/3, abs, basement, conduit, garage
Leaking drain pipe under kitchen sink dethun Plumbing 20 09-26-2012 08:30 AM
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 9 08-21-2011 03:17 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 06:17 PM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
