Above Range Microwave Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 01:17 PM   #1
Above Range Microwave question
Hello,
There are a lot of threads out there asking about this, but I wanted to give my specific scenario to make sure I am on track.
I am planning to purchase an AR microwave requiring 1000W - pretty standard. I currently have the original range hood which is hard wired and there are no outlets installed in the above range cabinetry. I checked and the circuit running to the range hood has a 20 AMP breaker and I am assuming 120V. The only other items running on this circuit are a pair of ceiling lights (one eyeball above sink and the primary ceiling fixture - both 60W bulbs). My question is, to avoid running a new circuit, can I just use the existing range hood wiring and install an outlet in the cabinet? I am not too experienced at wiring-I just added up a total load capacity of 20 AMPS or 2400W and the actual load if everything is on would be 1000W for the micro and (60W + 60W) 120W for the lights = 10 AMPS or 1120W. Sounds like a risk or should I be good here?
Thanks for any advice!
scripkilla is offline   Reply With Quote
Old 12-23-2012, 01:34 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
You really need to run a new circuit for the micro/hood.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
NJMarine (12-23-2012)
Old 12-23-2012, 02:33 PM   #3
Rewards Points: 528
Are you using a regular stove under it or gas?
hidden1 is offline   Reply With Quote
Old 12-23-2012, 03:05 PM   #4
Rewards Points: 758
Huh???
In my house gas would be a "regular" stove.
Check the installation manual for the OTR microhood. It probably specifies a dedicated 20 amp circuit.
AandPDan is online now   Reply With Quote
Old 12-23-2012, 03:17 PM   #5
Rewards Points: 528
If the outlet to the gas stove is a dedicated 20 you can plug it in there.Is best it is on its own circuit though.
Old 12-23-2012, 05:00 PM   #6
Thanks everyone. I have decided to add a new dedicated 20 AMP circuit!
Old 12-24-2012, 07:02 PM   #7
Rewards Points: 528
Thats the way to go.!
Range 50amp 6/2wire NEC Question? kgbishop Electrical 7 12-12-2012 11:15 AM
Venting an oven range microwave demandrew HVAC 47 03-14-2012 06:15 AM
danby over the range microwave terhen1 Appliances 0 10-08-2010 02:48 PM
Removing over the range microwave from wall mount islic Appliances 8 07-20-2010 02:00 AM
Range hood and microwave shelf install??? osueric27 HVAC 2 01-05-2009 12:01 AM
