-   -   above ground pool wiring (http://www.diychatroom.com/f18/above-ground-pool-wiring-26544/)
bobcatnj 09-09-2008 03:36 PM
i'm installing an above ground pool that i got from a friend. i need an electrical permit from the town, i live in. i never installed outdoor electric before so i need some help on this. also i am not an electrician. i was going to tap into the power in my garage and run the wire underground in a conduit to a convered gfi on a 4x4 post. would this be right? what size wiring would i use? anything else would be great. thanks in advance
Speedy Petey 09-09-2008 03:47 PM
Wow, you are asking for detailed info on a decent sized project.
It's NOT as simple as running power from your garage any more.
Se here for a start: http://www.selfhelpandmore.com/home-...pools-2002.php
Mightyidi 09-09-2008 08:07 PM
ifs its a 120 volt plug in pump the code requirements are minimal.
you just need a dedicated ckt, like a 12/2 uf(direct burial underground feeder) wire and install a gfi receptacle where you would plug in the pump,and any and outlet within 10 ft of the pool has to be gfi protected along with lights.
Even though this is simple to an electrician if you don't have experience being or working with an electrician.....hire someone..... doing this wrong can endanger you and your family
Speedy Petey 09-09-2008 08:13 PM
Mighty, this information is SO wrong it's not funny. :eek:
I suggest you brush up on your code before posting what you "think" is correct.
- NO UF cable for the outside wiring portion. Conduit and an insulated ground are mandatory.
- If the pump receptacle is between 5'-10' of the pool it MUST be a locking type.
- ANY receptacle for a pump motor MUST be GFI protected.
- NO other receptacles can be within 10' of the pool.
- You MUST have a GFI protected general use receptacle within 10'-20'of the pool.
- The cord on the pump can be NO longer than 3' and MUST have an insulated ground of no smaller than #12.
This is just the start, shall I get into equipotential bonding?
I hardly think this is "minimal". :whistling2:
chris75 09-09-2008 08:14 PM
So minimal, your incorrect, you cannot use UF. You cannot just use a gfci for the pump, unless you meet the required distance. The list goes on and on.
Speedy Petey 09-09-2008 08:16 PM
I see from another thread you say you are an electrician?
Mightyidi 09-09-2008 08:30 PM
dude relax....this guy is asking on a website how to wire a pool....how much detail do you think he will understand??? or even follow and true once I saw it your right the ground needs to be insulated....opps my bad .....but there are much fewer requirements compared to an inground pool thats what I meant by minimal
chris75 09-09-2008 08:31 PM
So because this is a DIY site they dont have to do it to code? I dont think the OP would have asked for help if he was just going to hack it in. :whistling2:
wire_twister 09-09-2008 08:32 PM
Speedy,
Is this the same guy that said electricians do service upgrades live?
Mightyidi 09-09-2008 08:34 PM
yes I think the people asking for advice on a website are not going to do it by code.....Ive worked side by side with guys who have been helpers for yrs who can't do it by code and your going to explain on a web page how to do it. and have the person do it correctly
Speedy Petey 09-09-2008 08:34 PM
NO DUDE, I won't relax. Not when I see a so called electrician give completely wrong information on how to wire a pool for sh*t's sake!
Why not give the information that is code and safety accurate?
He had better understand ALL of it.
Speedy Petey 09-09-2008 08:35 PM
Then WTF are you doing here???? Why are you wasting your energy typing?
Mightyidi 09-09-2008 08:35 PM
and yes I do service changes live try calling con ed and have them shut off the power...they'll have you on hold longer than it would take you to do the job
Mightyidi 09-09-2008 08:37 PM
ehh I'm married with kids .... this is all I can do....help....
Speedy Petey 09-09-2008 08:38 PM
You're not helping.
