Above Ground Pool Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 10:08 AM   #1
Above ground pool electrical
I just bought an above ground pool that is 52 inches high and 15ft long. I have not opened it yet and have heard that it can only be 20 ft from the electric outlet. My outlet is currently about 27 ft from the outlet. Should I return my pool? it is the only place I have that is flat. Would it make a difference If I bought a bit smaller pool?
notsohandymom is offline   Reply With Quote
Old 06-23-2011, 10:09 AM   #2
Licensed electrician
Rewards Points: 1,506
Why not have a new receptacle installed?
Old 06-23-2011, 10:12 AM   #3
that is an idea. I was hopeing not to have it to much more expensive than it already is. Is there any real reason why an extension chord the 27 ft wouldnt work?
Growing Grass after removing an above ground pool mhp8982 Landscaping & Lawn Care 24 04-22-2011 07:10 AM
Grounding/bonding of new above ground pool ms1976 Electrical 2 03-30-2011 05:27 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 10:12 AM
Slab Ground pool inspection alexromu Electrical 6 08-06-2008 07:01 AM
