#31 | |
It was a dark and stormy
Above ground pool #8 bonding wireQuote:
With Mr. Holt's video, the thing seems to be, "Should you bond to metal that is insulated from ground, to the pool metal which is grounded?" If all metal is at the same potential, then no shock ever because no current flow. If you touch a piece of metal that is insulated from all other conductors, then no shock ever because no current flow. If future work by clueless people working for PoCo or otherwise changes this grounding situation then you may have a problem. |
#32 | |
E2 Electrician
So when we step out of a pool, while one foot is in the energized water, were not touching something at "ZERO" volts... causing a shock hazard... not everyone understands what bonding is actually doing... We are actually "ENERGIZING" areas around a pool. Last edited by stickboy1375; 05-30-2012 at 05:39 PM. |
#33 |
E2 Electrician
Above ground pool #8 bonding wire![]() Here is the updated photo. Notice the dates on the photos.
#34 |
Licensed electrician
That is why the water is now required to be bonded also.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#35 |
E2 Electrician
Above ground pool #8 bonding wire |
#36 | |
#37 | |
Licensed Electrical Cont.
I see you just watched this new video. LOL
Did you feel this way last week??? Quote:
HOW is this ANY different than the fence, antenna, etc??? Sorry, I DO NOT agree with you or Mr. Holt in this case.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#38 |
E2 Electrician
#39 | |
E2 Electrician
Why would you want it energized? That is my question. I didn't just watch this video, but i do seek knowledge to things I don't understand. And i found this video very educational vs what you would learn in the trade, or on an online forum.
#40 | |
E2 Electrician
Because, how are you going to get shocked by a door frame while entering or exiting a pool? personally Speedy, I have never done a pool that close to a structure to begin with, so I'm not really worried about this code section, but i can tell you that I will never bond a window, door or gutter either.
#41 |
E2 Electrician
#42 | |||
You obviously do not want it energized. But those things will be NO MORE energized than the fence, antenna, ladder, handrail, etc. Quote:
In Mr. Holt's own example, the lifeguard grabbed both rails, one was bonded, one was not. EXACT same situation. Quote:
If it was code, yes. Those pictures are not in my code book.
#43 | |
E2 Electrician
In general, I hate how pride becomes an issue with being wrong, personally, if Im wrong I want to know, but in a nice way. The thread about dead ended wires being in a wall was tasteless and lets just say, less to be desired for.
#44 | |
#45 | |
IIRC fresh water in the pool is less conductive than concrete and so you've got ground currents flowing through resistances of different values and so you almost certainly will have potential differences. It is sort of a three dimensional electrical network with excellent conductors, and semiconductors (water, concrete, earth, human bodies). If anybody has a pool and a voltmeter I'd like to see what kind of voodoo voltages you get. >2v is probably troublesome. In the US, less than 5000 fatalities per year is "down in the noise" and elec. fatalities are about 1700/yr. Public policy and NEC policy is about making these kinds of tradeoffs. |
| Display Modes | |
| Adding a ground wire to a fixture? | dkeith | Electrical | 2 | 06-01-2011 09:08 PM |
| Ground rod or not? | brotherman | Electrical | 30 | 07-15-2008 05:58 PM |
| Pool Care Guide | scottiedog | Landscaping & Lawn Care | 16 | 06-07-2008 09:41 PM |
| Wire size for 300watt trans, 3 way 100ft | Al the Diy guy | Electrical | 16 | 03-22-2008 09:46 PM |
| Subpanel feeder questions | Silhanek | Electrical | 4 | 03-22-2007 07:30 PM |
