Old 05-29-2012, 09:25 PM   #1
Above ground pool #8 bonding wire
I have put the #8 bond wire around pool I know it needs to connect at 4 points to the pool but where do I connect the two end pieces ???
jerseymom3 is offline   Reply With Quote
Old 05-29-2012, 09:30 PM   #2
Licensed electrician
You are going to need to connect to the water bond, any lug on the motor and any other metallic parts that are in the bonding zone. This may include metal window and door frames.
Old 05-29-2012, 09:44 PM   #3
E2 Electrician
stickboy1375's Avatar
Why on earth (pun intended) would you intentionally energize a window or door frame?
stickboy1375 is online now   Reply With Quote
Old 05-29-2012, 09:51 PM   #4
A bond wire is to ensure that all conductive surfaces are at the same potential so that a shock would not be possible. Think of a bird on a wire.
Old 05-29-2012, 11:59 PM   #5
Semi-Pro Electro-Geek
??? I don't get it. All conductive objects within the bonding area must be bonded.
mpoulton is offline   Reply With Quote
Old 05-30-2012, 06:11 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
How in the world would you propose the frame would become energized.
This is a bond, not a ground. You do know the difference?
If a metal frame of a window or door is within the specified are then it must be bonded, plain and simple.
Old 05-30-2012, 06:18 AM   #7
Code05's Avatar
I like pictures.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Speedy Petey (05-30-2012)
Old 05-30-2012, 08:20 AM   #8
Licensed Electrician
k_buz's Avatar
The fact Jim and Speedy are pointing out here, is a good one and one that is also required for hot tubs.
Old 05-30-2012, 08:26 AM   #9
The picture does not help this is above ground pool. I think this is a stupid code for above ground when my pool is not metal but I can't pass until I do this I layed the wire but had no idea where to connect the two ends. Does one go to filter other go to water bond plate? These new codes are stupid and just cost homeowners more money
Old 05-30-2012, 08:50 AM   #10
I am sorry you consider that measures to enhance life safety are stupid.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Ravenworks (05-30-2012), Speedy Petey (05-30-2012)
Old 05-30-2012, 09:30 AM   #11
It is stupid for above ground pool that is not metal. I understand the codes for inground. I mean you can get a blow up pool and just have a extention cord pluging it in. I have a gfi braker for pool it just is way to much for above ground pool. The pools never needed this I had one when I was younger everyone survived. Everyone has there own opnion I only came on site to ask a question.
Old 05-30-2012, 09:34 AM   #12
k_buz's Avatar
I guess you think seat belts are stupid too?
Old 05-30-2012, 10:01 AM   #13
It was a dark and stormy
Yoyizit's Avatar
Originally Posted by Code05 View Post
I like pictures.
I think non-conductive steel is made of unobtainium.
You might have been lucky.
I think some NEC rules are just to make money for elec. manufacturers with very little increase in safety for the HO but I'm not so sure this rule is one of them.
Old 05-30-2012, 10:04 AM   #14
Non-conductive steel has a coating applied.
Old 05-30-2012, 10:06 AM   #15
I am talking about bonding wire not seatbelts what does that have to do with anything!! I ask a simple question . But now that you brought it up yes it is stupid that its a law that you have to wear one It should be MY CHOICE I should not be told what I have to do. My car my life should be my CHOICE I am hurting noone but myself. I'M done with that I came on here to ask a question I thought I could get an answer not get stupid yes I said stupid comments back
Adding a ground wire to a fixture? dkeith Electrical 2 06-01-2011 09:08 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Pool Care Guide scottiedog Landscaping & Lawn Care 16 06-07-2008 09:41 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
