Above Code Obsession - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 06:04 PM   #16
joed's Avatar
Rewards Points: 13,766
There should be no current on the plumbing/ground. It sounds like you have a neutral issue between the panel and the POCO.
The Following User Says Thank You to joed For This Useful Post:
brric (04-23-2012)
Old 04-23-2012, 06:09 PM   #17
Pure Genius
Rewards Points: 150
Originally Posted by kevinp22 View Post
1. Driving 8 ground rods and the wire must be continuous (I drove 4 but the #6 copper wire from the panel to rod 1 is 1 wire and the #6 wire from rod 1 through rod 4 is another wire but both are properly clampled to rod 1 with an acord clamp). Funny, even with 4 rods there is almost no current through the rods versus 2-3 amps through the traditional cold water pipe ground
Amps or Ohms?
Dierte is offline   Reply With Quote
Old 04-23-2012, 07:27 PM   #18
kevinp22's Avatar
Rewards Points: 252
Amps as measured by a clamp tester
kevinp22 is offline   Reply With Quote
Old 04-23-2012, 10:23 PM   #19
Rewards Points: 150
I thought I was hyper-code.
1. 8 ground rods. Is he listening for ET to phone home? I have a saying about fault tolerence, "0 spares is asking for trouble, 1 provides fault tolerence, 2 provides peace of mind, 3 spares is just paranoia." My house uses the rebar in the basement for the ground (yes it is noisy), which I plan to update. The funny part is the big braided jumper wire around the water meter to ground the pipes, which does a lot of good when incoming connection is plastic.
2. My rule is any outlet near a sink is on a separate circuit based on the assumption in front of each sink is a person with a hair dryer.
3. 2 or more counter circuits, separate refrigerator, separate low wall circuit, separate high wall circuit for the kitchen.
4. Since I don't have central air conditioning, separate 20 Amp circuit (1 plug) under 1 window in each room for room AC. (This summer's project)
goosebarry is offline   Reply With Quote
Old 04-23-2012, 10:55 PM   #20
Get an amp meter and see what different devices/circuits draw.
Billy_Bob is offline   Reply With Quote
Old 04-24-2012, 07:41 AM   #21
joed's Avatar
It can if used properly.
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
Plumb island sink and AAV code for Ajax jhakkim Plumbing 2 02-13-2012 11:07 PM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 10:13 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
