Forums | Home Repair | Home Improvement | Painting | Interior Decorating | Remodeling | Landscaping
Old 05-09-2010, 11:04 AM   #1
Share |
About watts on comsumption
Will more watts consume more electrical power ?. I am trying to get me an Air Conditioner but the electrical network in the apartment can only hold few appliances. Will lesser watts on the Air Conditioner contribute to less consuming thus allowing me to plug more appliances during hot summer days.
Sorry about my ignorance.
Thank you much
sitopons is offline   Reply With Quote
Old 05-09-2010, 11:42 AM   #2
joed's Avatar
Watts= power. So less watts = less amps = less power used.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 05-09-2010, 12:12 PM   #3
You are charged for electricity by the "Watt Hour". Amps while in the equation mean little in this question.
Old 05-09-2010, 12:46 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
What the others said.
I'll also add:
So obviously less watts equals less cooling.
Optimally, you need to get a unit that you can plug in without overloading the circuit, yet will provide adequate cooling.
Old 05-09-2010, 02:54 PM   #5
Look at the appliance nameplates to see how many amps each draws.
You might need heavy duty extension cords to apportion your usage among the breakers and the outlets that are fed by them so you don't exceed any one breaker's capacity. Using these cords is not as good as plugging directly into outlets, but what is your choice?
You might want to research a 'soft start' window AC.
Old 05-09-2010, 07:57 PM   #6
Too small a unit in terms of cooling capacity can run more than a properly sized unit of larger capacity netting an increase in electric usage. However I understand you are more interested in the watts consumed at any given time vs. overall power usage.
First see if a properly sized unit in terms of cooling capacilty will meet your power draw restrictions, if so you are good. If not, you may have to make a compromise by getting a smaller cooling capacity unit. But obviously you have to have a unit that will provide the desired cooling benefit else all is a waste.
Look for higher effiency units - more cooling BTU per running watts consumed.
How to wire three switches on one circuit Abs777 Electrical 12 03-25-2010 03:15 PM
How to Increase the Watts in my Solar Panel? rdlrn19 Green Home Improvement 1 03-02-2010 06:55 PM
Watts up with HD's product line? KE2KB Plumbing 2 03-25-2009 10:10 PM
Watts vs. Volt-Amp Billing? Max P Electrical 19 07-24-2007 07:05 AM
Watts to Amp Rze Electrical 2 08-10-2006 12:57 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
