Abandoned 220v Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 06:35 AM   #1
abandoned 220v circuit
I see all the time on the TV shows, guys will abandon a 220v circuit by tying the red/black together to form a short and leaving the breaker turned off... this seems counter intuitive to me, so...
What is the idea behind this practice?
What building code are they using?
BackNBlackTJ is offline   Reply With Quote
Old 06-26-2011, 07:17 AM   #2
DIY staff
Rewards Points: 7,174
Where did you hear of that one---that's just not a 'common practice'---when a line is abandoned the wires are disconnected from the breaker--and capped---never tied together.
Never heard of creating a 220 dead short intentionally.
hpp58 (06-26-2011)
Old 06-26-2011, 07:58 AM   #3
I=E/R
a7ecorsair's Avatar
I think you should change channels
a7ecorsair is offline   Reply With Quote
The Following 2 Users Say Thank You to a7ecorsair For This Useful Post:
electures (06-26-2011), gregzoll (06-27-2011)
Old 06-26-2011, 09:13 AM   #4
Licensed electrician
Rewards Points: 1,754
I have heard this before and think it is stupid. Remove the wiring or cap in an accessible junction box.
Old 06-26-2011, 10:17 AM   #5
Too Short? Cut it Again!
Scary. Disable it all at the circuit breaker box.
Old 06-26-2011, 10:28 AM   #6
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Wirenut each wire seperately. You don't have to, but you can also disconnect the wire from the breaker. In the future you may need it again or as a 120V circuit.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-26-2011, 08:47 PM   #7
Rewards Points: 1,536
Can you give the names of the shows or the show hosts?
Unused wires should not be cut off or tied together. They should be saved in place for future use, and disconnected from the circuit breakers..
AllanJ is online now   Reply With Quote
Old 06-26-2011, 09:06 PM   #8
electures's Avatar
Yeh, Holmes.
Old 06-26-2011, 10:17 PM   #9
Missouri Bound's Avatar
Is there a code reference for that?
Old 06-27-2011, 01:01 AM   #10
" Euro " electrician
frenchelectrican's Avatar
That part I have to dig it up however it boil down to more common sense what ya doing with abanoned cable or conductors I always just put a wirenuts or tape them out indivually.
Merci,
Marc
Old 06-27-2011, 01:51 AM   #11
Semi-Pro Electro-Geek
Rewards Points: 2,970
Merci,
Marc
Ha, I don't think that was intended to be a serious question!
mpoulton is offline   Reply With Quote
Old 06-27-2011, 12:51 PM   #12
electures's Avatar
None. Just commen sense. If the wires are shorted and somebody throws the breaker.......BOOM! It'll scare the crap out of someone for sure.
Old 06-27-2011, 12:53 PM   #13
electures's Avatar
Smile
Ahhhhh! Just caught that.. Little slow on the uptake today.. Thanbks for the laugh.....
Old 06-27-2011, 02:59 PM   #14
Gotcha!
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Fridge/Disposal on same Circuit Atskodinski Electrical 6 01-07-2011 07:38 PM
4 way circuit to a 3 way circuit BigAtl Electrical 8 12-16-2010 01:59 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 10:46 PM
