Abandon Romex? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 11:44 AM   #1
Abandon romex?
Hello all,
I am re running some circuits in order to move a fixture. The 14/2 that I am replacing is stapled to the studs and is stacked with another 14/2 cable. I am replacing only one of the 14/2 cables.
I am concerned that if I try to remove the staples from the bundle of wires, that I will damage the cable that I am not replacing. Is there an appropriate way to abandon a run of wire in a wall? The drywall is off and I am down to the studs.
Thanks much
Brian
b_corwin is offline   Reply With Quote
Old 01-18-2011, 11:53 AM   #2
joed's Avatar
Rewards Points: 11,596
Cut is short so it can't be used and leave it if you like.
If you cut the unused NM near the staple you should be able to pull it out. It should not be stapled tight.
Old 01-18-2011, 12:41 PM   #3
Licensed electrician
Rewards Points: 1,030
Using a pair of angled cutters you can lever the staple out of the stud to allow you to remove the abandoned cable.
Old 01-18-2011, 01:11 PM   #4
Rewards Points: 256
If you have the studs open, get the wire out.
If you are abandoning wire that you can't remove, then take all the wires, strip the ends, twist the wires together and cap and tape. Do this to both ends of the wire.
This way if someone energizes the wire not knowing where the other end goes it will immediateley trip the breaker.
I also do this when I rough in wires for later use.
michaelcherr is offline   Reply With Quote
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 02:53 PM
Is metallic ceiling box OK for Romex? Ultrarunner2017 Electrical 6 12-04-2009 01:03 PM
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 06:55 AM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 06:01 PM
