AAA Battery Holder - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 11:19 AM   #1
Rewards Points: 119
AAA Battery Holder
Hi,
I use a a the following battery charger to charge my Ni-CD/MH batteries and I am wondering if this battery holder is meant for the purpose.
Can I connect it to the charger I own to charge my AAA batteries?
What would be the use of and On / Off Switch
(like for instance in the Philmore # BH4411) for battery chraging?
Thank you
Alex
Metallo is offline   Reply With Quote
Old 01-09-2011, 05:28 PM   #2
Rewards Points: 119
Anybody?
Alex
Old 01-09-2011, 05:54 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,902
Originally Posted by Metallo View Post
Hi,
Thank you
Alex
Sure, that will work. Just make sure you set an appropriate charging current for your batteries - probably near the lowest current the charger allows. I don't understand your question about the on/off switch.
mpoulton is offline   Reply With Quote
Old 01-09-2011, 06:28 PM   #4
Rewards Points: 119
Thanks for you reply.
Well, my question regarding the ON/OFF switch is just to understand what's the purpose of such a switch, it can be obvious but if you disconnect the holder from the battery charger, probably a switch is useless in my case. Perhaps you can use such an holder as a power supply and choose to turn it ON/OFF be means of the switch?
Alex
Old 01-09-2011, 07:36 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,... That's my guess,...
If the pack was used to power something, rather than to charge the batteries...
Old 01-09-2011, 07:36 PM   #6
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,314
Those are just general hobbyist battery holders, not specifically for battery charging. Any one of those will work.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-09-2011, 07:41 PM   #7
Rewards Points: 119
OK, got it.
Thank you!
Alex
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 06:40 PM
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 02:31 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 06:34 PM
Milwaukee v28 Battery Life r62ewa Tools 12 12-04-2008 07:58 PM
Ryobi 12v battery system JElson Tools 3 10-11-2008 10:50 PM
