1000w for outdoor lights...Wow
How about installing CFL's instead?
If you like a yellow light buy the normal CFL's
If you like a brighter light buy the Daylight bulbs
They do have bulbs that look just like a normal bulb
40w Equiv in CFL uses 9w!!
So 45w per fixture x5 = 225w TOTAL!!
Problem solved - use #12 wire (due to Voltage drop - use #12)
1st 200' will have to handle 225 watts
2nd 200' will have 180 watts
3rd 200' will have 135 watts
4th 200' will have 90 watts
5th 200' will have 45 watts
You could even step up to 60w equiv CFL = 13w
So 65w per fixture x5 = 325w TOTAL!!
1st 200' will have to handle 325 watts
2nd 200' will have 260 watts
3rd 200' will have 195 watts
4th 200' will have 130 watts
5th 200' will have 65 watts
I have tried all different CFL bulbs & we like the Daylight bulbs for Main rooms. Reg bulbs for laundry & other areas
