90 Degree Fixture And Aluminum Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-20-2009, 11:52 AM   #1
Rewards Points: 79
90 degree fixture and aluminum wiring
I know that and both of these issues individually seem to cause some disagreement, so this is probably a bad combo, but I'd like to keep this thread simple if possible.
I want to replace the light fixtures in my 40 yr old house. Of course everything at the box store says 90 degree, so I was going to pigtail all of the fixtures in a new Jbox as I've seen suggested on here. Took down one of the fixtures and it looks like some of my overhead circuits are AL instead of copper.
Using an approved connector , am I still ok to pigtail the cu to the al in a different JBOX that will only be attic accessible, and run the pigtail into the fixture's box? I've seen mention of alumiconns and ideals in a switch or receptacle, so wasn't sure if that type of connection had to be easily/directly accessible at the point of the connection.
Thanks,
Mike
tigereye is offline   Reply With Quote
Old 10-20-2009, 01:14 PM   #2
300zx's Avatar
Post
Needs to be accessible in box with blank cover here are some links to read http://www.kinginnovation.com/produc...cts/alumiconn/ and http://www.inspect-ny.com/aluminum/aluminum.htm
300zx is offline   Reply With Quote
Old 10-20-2009, 01:24 PM   #3
Rewards Points: 160
The first link shows what I would call a great solution to your problem. Since the AL and CU conductors do not touch each other, there can be no galvanic reaction. They also look to be the perfect size for use in the j-box.
If it worked before you worked on it. You did something wrong.
Old 10-20-2009, 02:25 PM   #4
Rewards Points: 79
Thanks for the advice. I've been reading the inspect-ny site since I first figured out that I've got AL wiring, and figured that Alumiconn would be the way for me to go.
Question about the definition of accessible... if I've got the jbox in an attic that's accessible via a scuttle hole is it considered accessible enough or do I need to make a hole in the ceiling and cover with a blank plate?
I think that I'd read that the attic method would be "ok" for a "regular" 90 degree copper pigtail, but wasn't sure for this instance.
Thanks,
Mike
Old 10-20-2009, 02:38 PM   #5
300zx's Avatar
Post
Thanks,
Mike
Yes in the attic is ok
Connecting Aluminum to Copper Oswald Electrical 31 05-11-2009 04:22 PM
90 degree wire Captflx Electrical 6 11-23-2008 04:46 PM
Aluminum Siding in Contact electric1 Electrical 1 03-31-2005 07:48 PM
