90 Degree Corners Around Beams - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 03:36 PM   #1
Rewards Points: 89
90 degree corners around beams
Hi guys. I'm trying to plan a conduit layout in the barn.
Does this proposal look ok? It's my understanding that this particular example shows the maximum of 360 degrees for one run between boxes.
What I'm particularly interested in here is whether wrapping around a beam like this to continue on is standard practice? I drew hard angles because I'm lazy, the real corners would be bends, of course.
I do NOT want to drill holes in my beams.
Oh, I'm also curious about the practice of running downstream wiring through each receptable box. My idea is to run 6 circuits through a single 3/4 EMT. I've read that 3/4 accommodates 16 #12 conductors. 6 circuits (120 and 240) would include 12 conductors (8 hots) and a ground for a total of 13. I read that any conduit can accommodate up to 9 hots before having to derate the capacity and use #10.
Does this all sound right so far?
Thanks!
tbeaulieu is offline   Reply With Quote
Old 04-09-2010, 03:53 PM   #2
Master Electrician
Rewards Points: 3,808
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/hjrr3ZUcnh4...</param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/hjrr3ZUcnh4...etailpage&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="385"></embed></object>
I would use saddle bends.
Derating begins with 4 or more current carrying conductors. IMO there is no need to derate but if you must know how it's done it can be explained.
brric is online now   Reply With Quote
Old 04-09-2010, 05:14 PM   #3
Rewards Points: 89
1. 4, instead of 9? Rats! That changes everything. I need to look that up again so I understand exactly what I'm doing.
2. That sadle bend is interesting. I wonder how big it would be on an 8" beam, though! I suspect that would really stick out a lot.
Thanks!
Old 04-09-2010, 05:16 PM   #4
Rewards Points: 506
Would LB fittings facilitate anything here? Might make the push/pull easier?
jlmran is offline   Reply With Quote
Old 04-09-2010, 05:21 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
The wire will not pull through the lb.
You have to feed the wire throught the lb, but it will make it easier for someone that has never bent a saddle before.
Old 04-09-2010, 05:33 PM   #6
Rewards Points: 89
I was just looking at the beam. How about something like this?
Old 04-09-2010, 05:53 PM   #7
The # used for derating is not only the number of hots, it is the number of current carrying conductors (CCC), which includes the neutrals.
4-6 current carrying conductors must be derated to 80% of the value in tables 310.16 thru 310.19 of the NEC.
7-9 @ 80%
10-20 @ 50%
Your initial post would have 12 CCCs, meaning you would have to derate to 50%.
Willis
williswires is offline   Reply With Quote
Old 04-09-2010, 05:57 PM   #8
Rewards Points: 89
Oh boy, this is NOT what I read in another conversation! They defintely discussed neutrals not counting. Wow. Thanks for cluing me in. I'd sure hate to end up with a mess of conduit. I was hoping for a cleaner layout. Back to the drawing board. Literally.
Old 04-09-2010, 05:57 PM   #9
joed's Avatar
Rewards Points: 12,332
Derating begins at 4 conductors. However for derating purposes #14 wires don't have a starting current of 15 amps. It is not until you get to 9 conductors that derating drops #14 current below 15 amps.
Old 04-09-2010, 06:08 PM   #10
Rewards Points: 89
I haven't found that table online yet, if it is.
My AUDEL books says:
4 - 6 = 80%
7 - 2 = 70%
Furthermore, it has an example of 14#, (I'm planning on all 20A, BTW, so was thinking 12#).
PARAPHRASED QUOTE:
If you have 4 14# wires in the conduit, derated to 80% you get 12A. Since there's no such thing as a 12A breaker, you upgrade to 12#, which handles 20A. Derated to 80%, you get 16A, which is the correct solution.
Old 04-09-2010, 06:15 PM   #11
Master Electrician
4 - 6 = 80%
7 - 2 = 70%
PARAPHRASED QUOTE:
Your derating begins at 25 amps for #14 and at 30 amps for #12
Old 04-09-2010, 06:34 PM   #12
Master Electrician
http://www.tnb.com/ps/fulltilt/index.cgi?part=TL291
http://www.tnb.com/ps/fulltilt/index.cgi?part=TL202SC
You could use these to go around the posts but your cost will increase sustantially.
Old 04-09-2010, 09:09 PM   #13
Originally Posted by williswires View Post
7-9 @ 80%
...OOPS -- typo - correct is
4-6 @ 80%
7-9 @ 70%
10-20 @ 50%
Willis
Old 04-09-2010, 09:38 PM   #14
" Euro " electrician
frenchelectrican's Avatar
4-6 @ 80%
7-9 @ 70%
10-20 @ 50%
I was going to mention to ya on that one.
Now to OP there is other way as you did make a drawing you can make a double offset kick which I done that pretty often.
However it is little tricky to do it first time but after that you will get a hang of it.
Merci,Marc
Old 04-10-2010, 07:43 AM   #15
Electrician
Rewards Points: 788
Your second picture is the start of a 4 point saddle, repeat that on the other side and you have your full saddle.
I am speaking as a canadian but would think the US would the same on this. Your neutrals can and can not be a current carrying. In a balanced system(2 hots and a neutral) the current on the neutral carries the unbalanced load and does not have to be counted. If your running a hot and a neutral(in this case the proper name would be the indentified conductor) it will carry the same as the hot wire so it has to be counted as current carrying conductor.
darren is offline   Reply With Quote
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
hanging weight off of tji beams?? summer76 Building & Construction 2 04-14-2009 02:00 AM
Installing stone on fireplace with NON 90 degree corners? Kiwi. Remodeling 4 02-11-2009 05:39 PM
cement board corners ponch37300 Kitchen & Bath Remodeling 3 01-25-2009 05:50 PM
How to Attach Two Beams at 45 Degree Angle on top of 4x4 Post? Ler0y Jenkins General DIY Discussions 21 07-18-2008 07:48 AM
