9 Wires In A Box - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 08:37 PM   #1
9 wires in a box
I have an outlet box that had no outlets in it. It's big enough for 2 outlets but i'm only using 1. There are 4 black 4 white and 1 bare wire in the box. If I use only 2 white 2 black and the bare wire the lights in the room don't work. How do I need to hook these wires up?
Rabbit592 is offline   Reply With Quote
Old 06-02-2012, 08:42 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
There is absolutely NO way for us to tell from here. You'd need to trace each wire/cable and tell us where they go. It's not like each wire in every box has one specific function. Sometimes several have the same exact function, just coming and going to different locations.
Why only one ground? Is this fed by conduit?
Old 06-02-2012, 08:48 PM   #3
It's in a mobile home. When I took the plate off the box, all the white wires were wire nutted together and the same for the black. I'm thinking that 2 of each of the wires continue on to the lighting in that room as the lights don't work with the outlet hooked up
Old 06-02-2012, 09:03 PM   #4
Sparky
Rewards Points: 510
Then that's how they have to stay, use short pigtails of wire to connect to your receptacle.
Techy is offline   Reply With Quote
Old 06-02-2012, 09:05 PM   #5
Just use 1 pigtail off the black and 1 off the white to the outlet?
Thanks so much for the help...had me confused
Old 06-02-2012, 09:12 PM   #6
If they were all spliced before, HOW is that confusing??
By breaking the splice you are obviously discontinuing power to something.
Are you absolutely comfortable doing this work? I get a VERY bad feeling from this.
Old 06-02-2012, 09:17 PM   #7
Well like I said Pete, there were no recepticles there, just the box with a cover on it. I'm just putting a recepticle in it. Wasn't sure how to do it but thanks anyway
Old 06-02-2012, 09:31 PM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The confusion was that why you would think that you could change the way things were wired and expect everything to work the same as it did.
Its a valid confusion.
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 08:00 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
