8 Wire To 4 Wire Thermostat Help Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2006, 02:47 PM   #1
8 wire to 4 wire thermostat help needed
No response over in HVAC so I apologize if this is a newb question but i searched and couldn't find the answer. I'm replacing a Honeywell manual thermostat with a Noma programmable. The Noma came with instructions for 2, 3, and 4 wire installation but the Honeywell i'm replacing has 8 wires, hence the confusion.
The Honeywell has the following connections:
  • 50/60Hz - 24V
  • com - 24V
  • heat
  • cool
  • com - fan
  • I - fan
  • II - fan
  • III - fan
The Noma has the following connections:
  • W
  • Y
  • R
  • G
and a jumper for HE or HG.
Anybody know what i should do?
dj petey is offline   Reply With Quote
Old 01-18-2008, 11:07 AM   #2
12 year IBEW member
do you have a mulit stage furnace or multiple furnace units.
heavyduty is offline   Reply With Quote
Old 01-19-2008, 12:49 AM   #3
Union Electrician
goose134's Avatar
sounds like a multi stage furnace. You may need to get a different programmable T-stat. I hate to say it, but a lot of these things are gear specific. Especially, in a case like this. Eight wire t-stat sounds like you may need to call in a temp. control guy. Contact your manufacturer. See what units will jive with your unit.
goose134 is offline   Reply With Quote
Old 01-19-2008, 08:32 AM   #4
Electrician
Whats the model # on the honeywell t-stat?
chris75 is offline   Reply With Quote
Old 01-19-2008, 09:10 AM   #5
Union HVAC Tech.
Wonder if he had heat the last two years??????
bigMikeB is offline   Reply With Quote
Old 01-19-2008, 09:11 AM   #6
Union HVAC Tech.
Maybe it was number 3, as in #3.
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 03:45 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
8 wire to 4 wire thermostat help needed dj petey HVAC 5 04-15-2006 12:20 PM
