8 Foot Fluorescent Lamp Trouble - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 08:44 AM   #16
Rewards Points: 1,062
The ballast is GOOOOOD!!! I verified it by wiring it up to a known good fixture!! (it was cold to touch when "on".)
So, now, I have bigger problems- its has to be voltage, right? I dont have a meter that measures 1000v....
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 01-16-2013, 12:17 PM   #17
Semi-Pro Electro-Geek
Rewards Points: 2,920
Since you know the ballast is good, you don't need to measure the output voltage. Just reconnect it in the right fixture, exactly the same way it was connected in your test fixture. Make sure the input power connections and the lamp socket connections are solid. If it still doesn't work, check voltage at the input (probes under the wire nuts). If it still doesn't work, then use a non-contact tester to check for power on the output wires - if they are hot and the fixture still doesn't work then it's probably a bad lamp socket.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-16-2013, 12:57 PM   #18
joed's Avatar
Rewards Points: 12,360
You don't need to measure 1000volts. You know the ballast is good so it has to be input power(120 volts) or the wiring between the ballast and the lamp holders. Or maybe a bad lamp holder.
Old 01-16-2013, 02:03 PM   #19
Whats the diffreence between the input wires and output? Is the input the white/blk? And output is red/blue?
Old 01-16-2013, 02:44 PM   #20
Electrical Contractor
jbfan's Avatar
Rewards Points: 382
Yes
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
noquacks (01-16-2013)
Old 01-16-2013, 08:41 PM   #21
Child Alert! Pull Up!
fltdek's Avatar
May sound stupid, but make sure its grounded correctly? Ive known fixtures to not work because of poor or no ground, especially fluorescents!
fltdek is offline   Reply With Quote
The Following 2 Users Say Thank You to fltdek For This Useful Post:
jbfan (01-16-2013), mpoulton (01-17-2013)
dry water line to the foot valve ksbnellis Plumbing 0 06-06-2011 11:37 PM
Old-Style Hanger to Ceiling Lamp CaptChaos Electrical 3 06-08-2010 08:21 AM
halogen desk lamp Banker 21 Lamp bh4bhwgm Electrical 3 09-29-2008 04:55 AM
trouble fitting 4 wires into three demondope Electrical 11 12-28-2007 11:58 AM
Do canned lights overheat? Not Sure Electrical 14 12-27-2006 07:44 AM
