8 Foot Fluorescent Lamp Trouble - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 11:21 AM   #1
Rewards Points: 1,062
8 foot fluorescent lamp trouble
have a 2 bulb, 8' fluo fixture, replaced ballast, but on 2 new bulbs (tubes), and no light. So, took Ohms readings of both terminals (one blue/red wires, other blk/white), and one terminal 160+- ohms, other 80 or so. Are these good readings? What is ideal? Am I on the right track?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 01-15-2013, 11:25 AM   #2
Rewards Points: 13,960
Checked for incoming power?
noquacks (01-15-2013)
Old 01-15-2013, 01:08 PM   #3
Good point, joe, but yeah, it is in a SERIES - theres a working unit before AND after it. Thats what is getting me. Other culprit could be the main feed wire could be grounding on the metal case/box.....but doubt it.
Old 01-15-2013, 02:41 PM   #4
joed's Avatar
Rewards Points: 13,294
Still could be a power problem. The wires on the ballast are smaller than the line wires and sometimes they don't connect even if the power wires do.
Old 01-15-2013, 03:00 PM   #5
OK, Joe, then what should I do? Check for voltage at the blk/wh low v wires? Or the red/blue wires? What should one get for V reading? What V should one see there? I already did ohms......
Old 01-15-2013, 04:59 PM   #6
In other words, if I take voltage of those wires going to ballast, what should I expect?
Old 01-15-2013, 05:42 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
Bad ballast.
The Following User Says Thank You to jbfan For This Useful Post:
Old 01-15-2013, 05:44 PM   #8
Originally Posted by jbfan View Post
Bad ballast.
guess it could happen, (mentioned in my 1st post I replaced with new). Have you ever seen a "new" ballast be bad?
Old 01-15-2013, 06:13 PM   #9
jbfan's Avatar
Rewards Points: 530
Many times.
Is the ballast warm to the touch?
We had this discussion in another thread.
Did you wire the new ballast like the old, of by the diagram?
Old 01-15-2013, 07:11 PM   #10
kbsparky's Avatar
Problem is, many times the new ballast needs to have the entire fixture rewired, or "creatively wired" for it to work properly.
One simply just can't replace the ballast and reconnect the wires as before, since many of the older ballasts are series wired, and the new ones are not.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
noquacks (01-16-2013)
Old 01-15-2013, 07:24 PM   #11
Semi-Pro Electro-Geek
Rewards Points: 2,970
Check voltage at the black and white (incoming power) wires on the ballast. Use a non-contact tester to check for voltage at the lamp sockets (voltage may be close to 1000V, so don't use a meter unless it's rated for that!). Test the lamps in the other fixtures next to it. Swap ballasts with another fixture. Do any other tests you can think of to isolate the problem.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Old 01-15-2013, 07:28 PM   #12
Missouri Bound's Avatar
Wired wrong, wrong ballast, wrong voltage, no voltage, wrong lamps.....bad ballast...that's a few things that could be wrong. Is this a magnetic to electronic replacement?
Do you want it your way or the right way?
Old 01-15-2013, 07:39 PM   #13
joed's Avatar
Tug on the power wire connections and see if they pull out. Undo the power wire connections and redo them.
Could also be a bad ballast.
Old 01-15-2013, 11:26 PM   #14
" Euro " electrician
frenchelectrican's Avatar
Is this a slimline ( single end pins useally either 60 or 75 watters ) or High Output ( recssed double pin useally 95 or 110 watts ) ??
That will make the differnce and if you have the ballast number if you can read it please posted to us we can indentify quick.
Did you check the incomming source to make sure you have power ?
With the slimline ( single pin verison ) look at the fixed end carefully to see if damaged concats or not.
Merci,
Marc
Old 01-16-2013, 06:44 AM   #15
wow, so much help!! Thanks, guys! Im on my way to work, where I will post the specs on the ballast. Meanwhile, I will try switching it to another lamp that works......
dry water line to the foot valve ksbnellis Plumbing 0 06-06-2011 11:37 PM
Old-Style Hanger to Ceiling Lamp CaptChaos Electrical 3 06-08-2010 08:21 AM
halogen desk lamp Banker 21 Lamp bh4bhwgm Electrical 3 09-29-2008 04:55 AM
trouble fitting 4 wires into three demondope Electrical 11 12-28-2007 11:58 AM
Do canned lights overheat? Not Sure Electrical 14 12-27-2006 07:44 AM
