8.8 Volt Drop - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 10:01 AM   #1
8.8 volt drop
What effect would an 8.8v drop have on a (a) fridgerator (b) 3x100 watt bulbs? Given: (120v of 20A run 220' on 10 gauge cable).
Joe Willie is offline   Reply With Quote
Old 04-14-2011, 10:24 AM   #2
Where are you getting this 8.8V number from? The refrigerator should run fine, and the lights will be slightly dimmer, but not noticably.
DetroitEE is offline   Reply With Quote
Old 04-14-2011, 10:48 AM   #3
Rewards Points: 1,514
Depending on what the voltage started out (at the main panel) you could shorten the life of the refrigerator, for example if the voltage went down to around 100-104 volts as the fridge kicks on.
The low voltage won't hurt the light bulbs, in fact incandescent bulbs last longer when given less voltage than they are rated for. The efficiency (amount of light per watt) will be less though.
Old 04-14-2011, 10:51 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Sounds like a homework question.
Kyle
Old 04-14-2011, 12:33 PM   #5
I got the 8.8% vd from a vd calculator given 10 gauge, 20 A, 220' normal conditions. I know the wisdom is to shoot for less than 5vd in any system. I just wanted to know from someone else's experience, what it would look like. a roll of 6-UF is $800, 10-3UF is $340 at HD.
Old 04-14-2011, 12:50 PM   #6
wareagle's Avatar
JW
my computer program 4% for 10 amps and 8% for 20 amps. a regular frig uses about 6 amps I think.
corrected prior post.
wareagle is offline   Reply With Quote
Old 04-14-2011, 01:10 PM   #7
joed's Avatar
Rewards Points: 12,900
The fridge and light won't be drawing 20 amps so the drop will be less than your calculator.
Old 04-14-2011, 01:18 PM   #8
Joed,
Thank you so much. That was the best information. I was figuring this using the breaker size, not the actual amps employed. I should be good at less than 5vd if I keep the two circuits loaded under 10A draw. Cool.
Old 04-14-2011, 02:21 PM   #9
Scared Electrician
Saturday Cowboy's Avatar
I'm not sure if this was an error or not, but note that it is not 5v of drop that we shoot for but 5% voltage drop. So @ 240v thats about 12v. Less is better of course.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Basement - drop ceiling jgrohol Building & Construction 11 04-01-2011 12:39 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 06:07 PM
240 volt circuit and 120 volt circuit to shed fortop Electrical 27 06-26-2010 11:37 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
