77amp Tankless Water Heater on 150amp House???
So I'm doing a rush rush rush job at reasearching whether or not to do a tankless or a tanked water heater... (garage flooded this morning).
I'm looking at purchasing a Titan N-180 Tankless water heater which calls for (I guess) two 220 lines for a maximum of 77amps. specs from titantankless.com are: 18KW * 220/240volts * 77amp Is this going to be okay for my house which only has 150amp service? There's a good change I will run hotwater, dryer, AC and possibly stove at same time in the eveings... maybe. |
You need to do a load calculation to know for sure, but I seriously doubt you will get away with it.
I have installed a couple.Then about a week later homeowner had me hooked up a reg waterheater some people love them others hate them Got Paid 2x:laughing: You will be pushing that 150 amp breaker
HA! that's funny! What do the people hate about them? I'm pretty new to the whole technology |
The better choice might be gas, if you have it, or go back to tank type water heater. A singlee 77 amp load on a 150 amp service will be taxing, along with the rest of the load you meantioned. |
Jeeze guys... I'm researching around and hearing what you guys are saying and I think you're right. I think I'm just going to get another tubby.
Is 3/4" plumbing still the standard? I'm hoping to just pop in the new unit in place of the old... you don't suppose I'll be that lucky right? My old tank was a 40 gallon (standard looking model) and only has about 6" on each side of clearance. Do you suppose a 50 gallon upgrade would be possible? I'll bring a tape measure to Lowes. ((Sorry for so many additional questions - I'm kind of hijacking my own thread... perhaps I should start a new one??)) |
The tankless click a lot as they try to anticipate water usage. For three weeks in Germany I never got the hang of taking a shower without getting some cold water on my head. A tub bath is different since the temps. average.
The savings isn't worth it anyway. It would take many many years to pay off the initial cost difference.
Another thing to consider is you'll need to get two 40 or 50 amp circuits from the panel to the tankless.
Unless the heater is right next to the panel, it'll likely be considerable work. Rob |
Note: Not to knock all TWH's. I like the "point of use" types on certain applications. |
Final project
Here's what I ended up doing. Fun DIY project...
I wanted to use the braided flex for both connections but it just didn't work out on the cold side. The bend would have been too hard. I had to replace the shut-off valve along with the water heater. Pretty bad when the valve failed as well as the tank... it made the interim time a bit of a pain since I couldn't shut off water from there. Electrical was MUCH easier than a tankless I'm certian... http://www.dnscompanies.com/images/carreraday/tank.jpg |
Looks Good Takes up alot more room Save Some $ and buy a hot water timer have it turn on when you use the most hot water. I would not own a Tankless Water Heater.:no: Good Job:thumbsup:
I've been searching the dog-doo out of Lowes and Home Depo's web site trying to find such a timer. I must not be using the right search words. I'm lost in the isles... |
Here is one from lowes http://www.lowes.com/lowes/lkn?actio...D89&lpage=none Think i like this one better Price http://www.homedepot.com/webapp/wcs/...r5&R=100088282
| All times are GMT -4. The time now is 12:24 PM. |
