6gauge 2 Cond. With Ground For Range? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 05:06 PM   #1
Rewards Points: 79
6gauge 2 cond. with ground for range?
I'm remodeling my mother in law's kicthen. She had an electric cooktop only that was supplied by a 6 gauge 2 conductor cable with a bare ground. She has ordered a standard range to go in place of the cooktop. Can I use this same cable to supply the range? Basically I would have two hot wires and hook the bare ground to the neutral terminal on the plug. I really can't pull a new wire due to finished ceilings in the basement. Any advice?
Thanks!
AndyH24 is offline   Reply With Quote
Old 01-28-2012, 05:16 PM   #2
Julius793's Avatar
Thanks!
The answer is NO. Btw what are the specs on the new one?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-28-2012, 05:20 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Thanks!
6-2 cable that is pretty broad defination of that cable so is this is a SE cable or NM cable I will post the photo and I will fill in the details what legit and what not.
This is a SE cable and it is legit on exsting installment but once you move your range to differnt location then it is no longer legit at all the code did change that to requried a full 4 conductor cable.
This photo I will show is NM verison and this is good for only straight 240 volt load on your range if they do not use the netural and by the way the bare conductor is not allowed for netural purpose that is a major no-no.
So let us know which one you have there.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
AndyH24 (01-29-2012)
Old 01-28-2012, 05:26 PM   #4
Julius793's Avatar
Merci,
Marc
The se cable still has a bare ground so putting a neutral load on it should still be not allowed. Is that correct?
Old 01-28-2012, 05:32 PM   #5
The SE cable is dual rated and the bare conductor is actually insulated by two layers so it is legit for netural useage.
It the same way with SE service riser for many homes use that from the breaker box to meter and from meter to service drop.
If you are not sure just wait either KBsparky or Speedypete or Jim will chime in and fill you in more details.
Readers I am sure you are aware with exsting installment of SE cables for stove and dryers that is very common methold until 1999 NEC code cycle change that and the Chicago Metro and some of NYC metro do not allow SE cable for range or dryer useage so that will affect it.
( second note The mobile Homes do not allow use the SE cable for range at all they have to be full 4 conductor it was allready in effect way before the NEC did change that )
Merci,
Marc
Old 01-28-2012, 08:43 PM   #6
Rewards Points: 79
well it looks like nm cable but the ground is twisted not solid. The house was built it 1972 and this is the original wiring. The guy at lowes told me to hook the ground to the neutral ternimal. Is there anyway to do this without having to rewire? I can a better look at the cable tomorrow and take a pic if need be.
thanks!
Old 01-28-2012, 08:46 PM   #7
Licensed electrician
Rewards Points: 1,266
Can you post a pic of the cable?
Old 01-28-2012, 10:58 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,900
Don't listen to him anymore. He should be fired. I worked in the electrical department at Lowes one summer in college. They specifically told us NOT to give electrical advice, even if we're qualified - and being qualified was not a requirement to work there!
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
frenchelectrican (01-29-2012), Speedy Petey (01-29-2012)
Old 01-28-2012, 11:14 PM   #9
Location: eastern coast i go where im needed to do things right
electrical
andy dont do it an open ground on a 220 line without returning to the buss bar properly is an arc magnet ask anyone with basic electrical exp
yeahitwasme is offline   Reply With Quote
Old 01-28-2012, 11:19 PM   #10
frenchie is 100% right its a big no no
Old 01-29-2012, 09:21 PM   #11
Rewards Points: 79
here's a pic of the cable.
Old 01-29-2012, 09:38 PM   #12
Julius793's Avatar
Looks like se cable
The Following User Says Thank You to Julius793 For This Useful Post:
Old 01-29-2012, 09:41 PM   #13
I think it looks like SE also.
Old 01-29-2012, 09:54 PM   #14
Frenchelectrician
Good for only straight 240 volt, what does this mean?
“This photo I will show is NM version and this is good for only straight 240 volt load on your range if they do not use the netural and by the way the bare conductor is not allowed for netural purpose that is a major no-no.”
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Hardway is offline   Reply With Quote
Old 01-29-2012, 10:22 PM   #15
Type NM cable with 2 conductors only could be used as 2 hots with a ground. You could not use the bare as a neutral. It was strictly for grounding.
Type SE cable with two conductors could use the bare braid as a neutral and could be used on 120/240 circuits prior to the code change to 4 conductors. It is allowed to continue in use.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
AndyH24 (01-29-2012), frenchelectrican (01-29-2012), Hardway (01-30-2012)
Ground rod and ground wire question mulltron Electrical 17 07-29-2011 06:10 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
