60W Max, Can You Use 100W Equivalent CFL (23W?) - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2012, 01:48 AM   #1
Rewards Points: 278
60W max, can you use 100W equivalent CFL (23W?)
I have light fixtures that has a sticker that says 60W max bulb. I wanted to know can I put 100W equivalent CFL which draws 23W?
DIYGST is offline   Reply With Quote
Old 12-28-2012, 06:05 AM   #2
Electrical Contractor
kbsparky's Avatar
You are proposing to use a 23 watt bulb in a fixture that is rated for 60 watts maximum?
I see no problem with that, as long as the bulb physically fits, and is rated for use in permanently installed (or enclosed if the case may be) fixtures.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
NJMarine (12-28-2012)
Old 12-28-2012, 07:40 AM   #3
Rewards Points: 6,652
It is just going to be brighter.
Old 12-28-2012, 01:10 PM   #4
Rewards Points: 186
Yes you can, the rating is based on heat threshold, assuming a 60w incandescent source, in a can light typically you have a temperature sensor which will cut off the light if it gets too hot. But you didn't mention if it was a can light or stand alone fixture.
Ocelaris is offline   Reply With Quote
Old 12-28-2012, 02:18 PM   #5
joed's Avatar
Rewards Points: 13,722
The bulb you want to use is only a 23 watt bulb so you can use it. The CFL equivalent rating are only for advertising.
Old 12-28-2012, 04:50 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,608
These maximum limits are based on standard incandesant lamps !
And are really a heat rating.
Using a CFL of any size will be fine,
as they dont produce much heat
when compared to incandesant lamps.
dmxtothemax is offline   Reply With Quote
What Sherwin Williams Interior Line is equivalent to the A-100 Exterior Paint? arjun90 Painting 11 07-29-2012 01:19 AM
Great stuff or equivalent product for cold weather? Red Squirrel Building & Construction 11 01-21-2011 10:19 AM
Sandblasting media equivalent spykus Automotive Repairs 6 12-19-2010 10:34 AM
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 10:59 PM
Ryobi chuck key Jacobs equivalent for DP101 bbmonster Tools 3 10-08-2009 08:53 PM
