-   -   60W max, can you use 100W equivalent CFL (23W?) (http://www.diychatroom.com/f18/60w-max-can-you-use-100w-equivalent-cfl-23w-167578/)
DIYGST 12-28-2012 02:48 AM
I have light fixtures that has a sticker that says 60W max bulb. I wanted to know can I put 100W equivalent CFL which draws 23W?
kbsparky 12-28-2012 07:05 AM
You are proposing to use a 23 watt bulb in a fixture that is rated for 60 watts maximum?
I see no problem with that, as long as the bulb physically fits, and is rated for use in permanently installed (or enclosed if the case may be) fixtures.
gregzoll 12-28-2012 08:40 AM
It is just going to be brighter.
Ocelaris 12-28-2012 02:10 PM
Yes you can, the rating is based on heat threshold, assuming a 60w incandescent source, in a can light typically you have a temperature sensor which will cut off the light if it gets too hot. But you didn't mention if it was a can light or stand alone fixture.
joed 12-28-2012 03:18 PM
The bulb you want to use is only a 23 watt bulb so you can use it. The CFL equivalent rating are only for advertising.
dmxtothemax 12-28-2012 05:50 PM
These maximum limits are based on standard incandesant lamps !
And are really a heat rating.
Using a CFL of any size will be fine,
as they dont produce much heat
when compared to incandesant lamps.
