60AMP Subpanel Wire Size/Type Question - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-28-2008, 08:21 PM   #31
QO120L125GC as subpanel?
Would a Square-D QO120L125GC work as my subpanel? Says it is a "main lug", is a main lug a sub panel---seems to be designed this way? It has a grounding bar installed and is only $58 at Lowes. I have an extra 60AMP circuit breaker I could use as a main switch in this (back fed).
xv144 is offline   Reply With Quote
Old 11-28-2008, 10:40 PM   #32
" Euro " electrician
frenchelectrican's Avatar
Yep it is legit and keep the netural and ground seperated on that location also make sure you get the main breaker tiedown kit { this is the only way to be legit on this set up }
Merci,Marc
Old 11-29-2008, 05:09 AM   #33
elect, contractor
Rewards Points: 27
I don't believe they have codes in my area. I am out in the country. Don't plan on having inspectors.
get an inspection, the codes are everywhere thats why its called the "national electrical code" the inspection is not to anoy you but to make sure you did not make either a major or minor error that could either burn your house down, electricute someone, damage electrically whatever you plug in or hook up, or at the least fail to work due to a problem a few years later.
I have lots of people coment "its my house I can do as I please" or some kind of comment along those lines, but when something happens or someone gets hurt or killed, guess who becomes 100% liable. when you insurance company denies your claim after your house burns down as a result, then what? if you are confident that your doing the job right then it will pass inspection and there will be no problem.
ACB Electric is offline   Reply With Quote
Old 11-29-2008, 04:58 PM   #34
Electrician
Originally Posted by jbfan View Post
My area adopted the 08 code, but left the 05 code in for gfci's and arcfaults.
Connecticut skipped the 2008 altogether. YEE-HAW!!!
chris75 is offline   Reply With Quote
subpanel question Brik Electrical 2 11-30-2008 05:31 AM
Can i add a subpanel fed by 10/2 wire? qst4sno Electrical 25 04-25-2007 05:14 AM
Another Neutral/Ground/Bonding Question michael5 Electrical 3 01-30-2007 11:38 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
New fixture wiring question Unregistered Electrical 1 02-22-2004 07:34 PM
